Coggonobrien's 616 Thread Picture Heavy |
Page 123> |
coggonobrien ![]() Orange Level Access ![]() Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1808 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Sep 2014 at 12:55am |
i've got a 620 lined up i need to pick up soon as a parts tractor, it has rear pto, front hydraulics, another deck, a single bottom plow, and a dozer blade
also need to dissasemble the brakes, right seems to be seized up. will get to that after harvest then we will throw the motor in and see what else is wrong once it's running.
Edited by coggonobrien - 09 Jan 2015 at 12:06pm |
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11623 |
Cog,
Any progress on your project 616? Just curious. Steve@B&B |
no progress, in the field now and I work in town. just collecting parts and will hit it hard when the snow fly's with the goal of having it ready to mow come spring
Hey Cog! You're gettin' there. Little by little. Now ya need ta' git' that engine set up. You're farther ahead than I am with my 620. Keep rollin' !
Slade (TN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: TN Points: 676 |
I want one someday!!! Or a 620, or a 720.......a miniature 190 :)
Cog! Did ya git' that motor set up and fired yet? Just curious!
Sugarmaker ![]() Orange Level ![]() ![]() Joined: 12 Jul 2013 Location: Albion PA Points: 8172 |
Cog,
That is a nice looking garden tractor. I would drive that! Looking forward to your restoration work. Regards, Chris |
no updates yet, just rounding up some parts for the engine install. Did get new blades, bearings, cups, and seals for the deck for christmas so I will be dismanteling that and blasting the shell, repairing some minor rust and reassembling. should hopefully start on the motor Wednesday.
David
i plan on swapping the ring gear over to the flywheel from the donor 616 engine assuming they are the same size since the teal engine is nos
Roach ![]() Silver Level ![]() ![]() Joined: 30 Jan 2013 Location: Wheeler, IL Points: 255 |
David, the pulley looks like the center main pulley on the mower deck of my 720. When I bought mine it had another pulley with it just like this one but a lot smaller in diameter. Don't know if they had different sizes for different mower speeds or not but not figured out anything else.
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
Gently take the 4 screws out that hold it to the block. That's how I removed mine to clean all the grass and crap out of the stator. Looks like that one has the same issues. Needs a good cleanup. Mine came right off Dave. I didn't have any problem with it. Inspect the stator wires for breaks or rub-thoughs. The wires on mine had a couple nicked spots. Its all repaired and ready to reinstall now.
Thanks guys.
Steve what's the proper way to clean the stator |
Dave,
I cleaned mine with Brakekleen and a new toothbrush. Got in the nooks n' crannys with the toothbrush, and washed it all out with the straw that comes with the Brakekleen. Came out like new. Then I cleaned the stator tips with a scotchbrite pad to get any corrosion or years of crap off of em'. Inspect the Magnets in the flywheel also to make sure they're still intact. I cleaned the flywheel all out to. Went through a can of Brakekleen between the two pieces... |
macvette ![]() Orange Level ![]() ![]() Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1656 |
Steve' comments about flywheel are spot on. A magnet came loose on mine and did considerable damage. Bought a used stator and flywheel from a forum member that was supposed to be good. Have also bought a new Onan regulator and rectifier and have about $450.00 stuck in job and doesn't charge. So disgusted after pulling engine twice looking for reason that I put back together last summer and gave up.
After consulting with Dr allis I'm going to use his method of a light soft brush and lots of air to clean the stator. No chemicals to ensure I do not damage the coating. Thanks for the advice everybody.
Edited by coggonobrien - 09 Jan 2015 at 10:01am |
Just order a replacement engine harness from B&B custom circuits.
Does anybody know a Delco spark plug # |
Chuck...the Janitor ![]() Silver Level ![]() ![]() Joined: 08 Oct 2014 Location: fairfield, Il Points: 78 |
just went to check and ACDelco C45L is what is on my 616. runs great too.
D-17_Dave ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
The left hand discharge mower decks used a smaller diameter cast drive pulley. These decks were used on the 5015 and 5020 tractors. With the lower ram diesel engines the deck had to be geared up to run a at 3600 ram. This was done with the smaller deck pulley. I have one of these smaller pulleys and can check the casting numbers but I'm not at home right now.
Yea, I can fix that.....
Page 123> |
