207430+910324 MIA
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Topic: 207430+910324 MIA
    Posted: 04 Apr 2010 at 7:34pm
Yeah, I thought that title might turn a few heads. Anyway, in case you didn't take the time to look them up, I am missing a Clip (90 degree angle one that pulls the mag into the gov.) and one of the nuts to put the magneto back on one of the B's. I "borrowed" a set from a different tractor for now but I will need to replace them at some point. Anyone know of any sources for these parts? Hopefully I can find them because I'm getting the feeling that they might be costly, at least the clip, to replace. Is the nut just a standard or will I need to special order that? Didn't get the time to look.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:39pm
morton  I would think you could make the clip out of a piece of flat strap, drill 3/8 hol then put in vice and hammer over to 90* HTH Mark L
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:49pm
I've thought about that. I wasn't sure if it would be too precise of a part to do, but I guess it wouldn't hurt to try.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 8:34pm
Morton, You have one to use as apattern. The nut is a standad hardware store item. You need a flat and lock washer also. Bob
