hd-5
jturano11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Topic: hd-5
    Posted: 26 Mar 2010 at 4:57pm
the boot on my hd-5 transmission for the plunger to lock my transmission in gear is not in usable condition, it is ripped badly and is leaking horribly.
             anyone know where I can buy a new one or a suggestion as to what I can do?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 5:10pm
If you find a source , let me know .
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2010 at 5:14pm
I should have some new boots locking plunger.
                                    gemdozer@hotmail.com
Tom6070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom6070 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2010 at 8:06pm
I've got a neighbor parting out an old style HD-5 with straight blade.  It hasn't run for 30 years but it has been covered up.  He is in NE Indiana.  He'd likely sell some parts if anyone is looking.  I believe the tracks are shot as is the engine.  Transmission and gears might be ok.
DonBC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonBC Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 11:02am
I don't know the shape and size of your boot but I have used the boot for the CV joint for a front wheel drive car as a gear shift lever boot.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2010 at 4:35pm
Do you know what kind of blade it is? Are the cylinders mounted on either side of the radiator? I have several bare tractors which don't have blades. thus the reason for my reply.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 12:03pm
i used a universal boot from my local carquest on my HD16 shifter.  just cut to fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 1:42pm
this a a boot about 4" long aprox 1" on trany end and 5/16" at the rod end.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 2:01pm
that is a different boot
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 2:03pm
that is the one
Post Options Post Options   Thanks (0) Thanks(0)   Quote jturano11 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 2:05pm
4inches in diameter
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 5:48pm
The hd5 boot for locking plunger is 2 " loog and part number 080166 and 049966
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 6:06pm
 I don't have any boots on hand but i can get them. Email me at mbscott881@frontiernet.net if your interested. Also send me your serial number since there are two different boots.   Thanks Matt
JimNEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimNEIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 7:53pm
I got an hd5 that I haven't had running in 4 years.Should pull and try to start it.Been thinking about scrapping it with the price of steel now.
190Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190Guy Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2010 at 9:55pm
   I can get you a new boot for your trans on your HD5. I will look up the price.  Let me know if you are interested. Email snydereq@verizon.net or call 1-330-223-1913 Thanks, Ray     I can also get other parts New and used for AC Crawlers
