engine swap
blazen orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blazen orange Quote  Post ReplyReply Direct Link To This Post Topic: engine swap
    Posted: 28 Sep 2014 at 8:25pm
OK here goes I swapped a Kohler 20 horse vertical shaft for a Briggs and Stratton 18 horse vertical shaft and the problem I'm having is the wiring. I was hoping someone would have a simple to read wireing diagram to make this swap work thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2014 at 9:05am
What I would do is go online, look up your model Tractor with the Kohler and find a wiring diagram. Next, look up the same Tractor or find an equivalent Tractor that's close that was available with the B/S engine and see what the difference is in the wiring. Probably isn't much difference...
Steve@B&B
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2014 at 11:57am
need  to know which reg. is on the briggs also antifire soliniods on the carbs its simple if you pm me that will be the easy way for me to get it hooked up
Post Options Post Options   Thanks (0) Thanks(0)   Quote blazen orange Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2014 at 3:53am
I actually found a diagram on line and got it figured out. It took me a while to find and after that I had it running in about a half hour thanks all the same guys.
