smoked my clutch
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: smoked my clutch
    Posted: 06 Sep 2014 at 8:37pm
Smoked my wd45 clutch. Pulled a 5 mph class and slipped it bad. 9 spring with stronger springs and a 6 pad disk. I do have a new organic disc at home. Will it hold up to say 70 or so hp. Going to have the flywheel turned.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2014 at 9:11pm
I believe Rick on here is the clutch expert.
His email is     rickinmo@socket.net
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2014 at 9:13am
3-pad disc will hold more than 4-pads.......4-pads will hold more than 6-pads. Fiber disc won't hold as much as 6-pads as a rule.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2014 at 10:53am
I need a number to get ahold of rick. My email won't work. Thanks.
190XT,D17and 7045
mgburchard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2014 at 5:00pm
Does anyone know if there's a pressure plate from some other brand that will fit the WD 45 flywheel that has more than 9 springs?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2014 at 9:35pm
Is there a valve spring that is stronger than the pressure plate springs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mgburchard Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2014 at 2:08pm
Oh yeah when you run 1.5 od valve springs for aggressive camshaft ramp profiles you start destroying 9 spring pressure plates why I need a tweleve spring plate .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2014 at 9:39am
You can run a spring inside of the existing spring, if you are maxxed out on spring pressure. Beyond that, a second disk and floater plate will double clutch torque capabilities.
WCCLASON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WCCLASON Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2014 at 8:13pm
yup... I am running 65 HP at the PTO and i have a stock pressure plate with a semi ceramic 4 puck disk... very jumpy but it locks up. Never had a slip. Bob i think that is the way u should go unless you are going to go way bigger with your motor. Contact Steves Ag Diesel if i remeber right and he will set you up with the same disk i have.
This page was generated in 0.180 seconds.
