fuel supply question
rowcropmafia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Topic: fuel supply question
    Posted: 17 Dec 2013 at 8:26pm
Building a 5.9 cummins and am looking at mechanical supply pump options. dont really want to spend 500+ on a waterman. Any hydraulic pump options out there or what are you guys using to feed your injection pumps?
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2013 at 6:18pm
There are a few options but basically you need a pump which will supply 3 GPM @ 1800 RPM if you drive it at crankshaft speed or a pump of around 6 GPM @ 1800 if it is driven at half of crank speed (front side of injection pump).
Here is a part number for a Tuthill pump which many use. It has it's own built in pressure regulator which is nice.
Tuthill part # 2LEV-CC
We use a Barnes pump from Northern hydraulic with an external regulator and get along fine. Much cheaper, but not as nice. You may call Schied diesel. They do a few Cummins applications. They may have something on the shelf that is a bolt on piece. Columbus Diesel also has supply pumps which work well with internal PSI regulators.
Happy hunting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rowcropmafia Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2013 at 7:45pm
I talked to mike at alkydiggers out of Nashville. Very nice guy, he was able to set me up with a rebuilt enderle pump. Seemed like his prices were good and has alot of inventory on hand.
This page was generated in 9.211 seconds.
