What is this?
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: What is this?
    Posted: 14 Feb 2010 at 1:02pm
After splitting the 170 at the bellhousing and removing the clutch this fell out from behind the flywhee[I
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2010 at 1:15pm
It is the plug at the rear of the block, covers the end of the camshaft .
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2010 at 1:24pm
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2010 at 1:33pm
I would have the flywheel checked while I had it out. It should be 1.437" from the surface that the pressure plate sets on down to the surface that the clutch plates sets on,JP
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2010 at 2:50pm
that appears to be a part left over.if the plug was missing very long you would have had a gusher of oil out the bell with engine running..
