I 60 backhoe
fastallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastallis Quote  Post ReplyReply Direct Link To This Post Topic: I 60 backhoe
    Posted: 20 Aug 2013 at 7:14pm
I just bought a I 60 loader backhoe. It is pretty rough but runs good. It is missing a few things. The hood sides are gone. The  pipe from the air cleaner to carb came with it but how does it connect at the cab? Another question? i think the hydraulic pressure relief is turned in to much if you bring a cylinder to the end of it's stroke you will kill the engine. How do you adjust that or is it normal? Thanks for the help?
Dan LaRowe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2013 at 8:09pm
There should be a pressure relief valve, on the valve bank, you will need to see if it is stuck shut, or screwed all the way in.  Carb to air cleaner should be just a hose, and hose clamps holding it on.
