Early B rear weights
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: Early B rear weights
    Posted: 27 Jan 2010 at 10:59pm
These are what are sometimes called "B Pancake" wheel weights. As near as I can tell from old photos this was the first weight designed by AC for the B. They have AM casting numbers in the outside
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2010 at 11:08pm
These fit perfect on the 38B with 2 piece split rims. Brett Phillips hauled them to NC from Paul B in MD. I hauled them to Texas from NC. They ended up on Garys 38B as authentic for the vintage wheel weights.
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 7:22am
Ken, we have a set of these on a B, but I was not able to find a casting number on the outside.  I have not removed them to check on the inside.  Do you recall what the casting number is?
A-C Weight ID reference and other goodies at brianahart.net
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 7:30am
I have a couple sets too. I had not checked them for a casting number.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 7:32am
These are  a common weight around here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 8:35am
The casting numbers on this set of B wheel weights read  AM 2795-7.
   I thought it a bit odd that the casting numbers on B/C engine sidewieghts are the same for both shapes. Those with or without the bevel on the clutch housing end.
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 8:45am
Picked up a set of those from a junkyard locally last summer. Had them blasted and painted.  Wasn`t sure how common they were.  It appears they are more common than I thought.  Planned to put them on my `38 B #7366 that I am nearing the finish line on.  Ken, was wondering what size and length bolts you used to mount them?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:00am
Ken, thanks for the casting number.
Do you mind if I use your weight picture on my website?  Your weight is prettier than mine, LOL.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jan 2010 at 11:11am
I have several of those B "cap" weights. Fred and I've been calling them "cap" weights because they do such a fine job of capping the standard B weights when stacked.That is how they were installed on my IB with the heavy all hydraulic sickle mower. On the left wheel only, to off set the weight of the mower on the opposite side.
The question now is; will they fit my B450 project with the early B "shallow dished" rear centers?
