My AC170XT |
chadsma ![]() Bronze Level ![]() Joined: 14 Jan 2011 Location: Garwin Points: 17 |
![]() ![]() ![]() ![]() ![]() Posted: 03 May 2013 at 10:13am |
Here are a couple photos of my 170XT.
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Never heard of one. Never saw one with those black stripes either. Learn something every day! Good looking unit!
SLee(IA) ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: Polk City, Iowa Points: 269 |
Is that a 433 from a 6080? Looks great in there.
Steve
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5104 |
NOW THAT is how they should have came from AC! VERY COOL!
wekracer ![]() Orange Level ![]() ![]() Joined: 13 Oct 2009 Location: Tebbetts, MO Points: 1590 |
that is pretty nice . Hope you turned it down some. That's a lot of power for that drive line
Seth Souerdike ![]() Orange Level ![]() ![]() Joined: 22 Nov 2011 Location: Cutler Indiana Points: 4113 |
That's really nice :D ive never seen the fenders black before.
There are no atheist in foxholes.
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3569 |
Great looking 170xt! Did you use a 433T or 433I engine? I'm guessing you used a gleaner K2 433T? Was it very difficult to marry up the clutch/transmission housing bolts? Did you use the existing front hydraulic pump on tractor or use an engine driven hydraulic pump mounted on left side of front plate? Are your rear tires 30"?
motor is out of a combine and is turbo and intercooled. had to make a spacer plate because clutch shaft was 1.75 too long and I used a 190 flywheel and clutch. had to make a new adapter for front pump. alternator moved to right side. used 180 water pump housing. tires are 18.4 28.
Nathan (SD) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Day County SD Points: 1284 |
Nice. What kind of road speed you got now?
The motor is out of a combine and it is turbo intercooled. I had to make a spacer plate cuz the clutch shaft was 1-3/4" too long. I made an adapter for the front hydraulic pump and used a 190 fly wheel and clutch. It has a 180 water pump housing and a 60/80 exhaust manifold. It has 18.4 28 tires.
The road speed is about the same as it was before the modify.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
ALLIS EXPRESS!
This year: |
JC-WI ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: wisconsin Points: 34352 |
I agree with Injection Pump Ed, "NOW THAT is how they should have came from AC! VERY COOL! " Yes, very cool indeed.
From viewing the changed color of the chrome exhaust stack, I imagine you have put it under load to see how it compares for pulling?? Was the original engine a 226 gas or 248 perkins?
226 gas and it was very under powered
REEDE ![]() Silver Level ![]() Joined: 24 Apr 2010 Points: 286 |
Nice looking tractor. I know you guys put a lot work in to it.
Jim Lindemood ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Pretty cool -- interesting setup.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22001 |
A model 170 with 16.9 x 28 rear tires at 2,000 rpm does 15 mph...........at 2400 rpm it would do 18 mph............18.4 x 28's would be more than that.
Don(MO) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Nice install! Looks like it came from the factory that way. Have you had her on a dyno yet, if so what HP did it show?
Flywheel was 95 HP, so PTO should be around 83 HP at 2,200 RPM (725 RPM PTO speed).
JCFarms ![]() Orange Level ![]() Joined: 03 Mar 2013 Location: Louisiana Points: 230 |
Cool
rw ![]() Silver Level ![]() Joined: 28 Oct 2009 Location: United States Points: 384 |
Good Looking set up. I can't quit chuckling at the comment about it being underpowered before with the 226 gas. My guess is you have twice the torque if not three times as much as the gas. You probably do notice it being a little more power. rw
