hauling d-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: hauling d-14
    Posted: 24 Jan 2010 at 7:33am
Am picking up my 59 D-14 in an hour.Quick question.
I know, I should have askedearlier but should  I drive it onto the car hauler forwards or backwards ????
Thanks for any help.
Jay
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:38am
depends if the rear tires have fluid or wieghts. if the rear tires are empty i would say forward. you will want to be able to adjust the wieght so that you have some of the wieght on the vehicle
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:42am
When I haul my WD45's I drive them on. I stop the tractor when the tractor rear wheels are centered between the axles. hope that helps. Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:44am
Bob, You are faster on the keyboard. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 7:45am
Thanks Guys, I appreciate the fast 'been there done that ' replies !!
Tires are air only, so I'll drive up centered on the traile axles.
thanks again.
Jay
weiner43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner43 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 2:45pm
Both times I hauled a tractor, I ended up pulling over and readjusting where the tractor sat. Both were movered forward.
God bless our troops and the United States of America.
Pick your rut well, you may be in it a long time.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 2:52pm
You will be able to adjust the tractor position so it rides better not to far forward but forward enough so you always have some tongue weight.
Herb(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Herb(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 3:39pm
Before loading, measure from tow ball to ground, record the dimension.  Load your tractor and drive it on to where the previous measurement is now one inch less.  This normally provides the preferred 10% loading on the trailer ball.  This has always worked good for me, and readily accomodates a big variety of loads (shop equipment, residential belongings, two AC G's, firewood, old shingles, etc).  Herb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 4:29pm
I'll have to remember that Herb. I've only hauled my D17D once on my 6X12 tandem axle trailer. The trailer handled the weight no problem, but I had no room to move the tractor around. About 50mph it felt like it was going to sway, so I kept it at 45 mph all the way from just east of down town Des Moines to Prairie City. It was driven on and had a full load of fluid in one rear tire and about 25% in the other.
Edited by Brian Jasper co. Ia - 24 Jan 2010 at 4:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 4:43pm
She's home safe and sound !, thanks to the 'words of wisdom' from you guys!!
So far I've removed the rear view mirror,replaced the right rear rim/tire ,spread the front axle to 60" and rewired the dist to 1-2-4-3 instead of the 2-1-4-3 order. Purrs like a kitten,roars like an Allis ! Time for some homemade chili...raining cats and dogs here.
Thanks guys, appreciate the help
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 4:50pm
That's great Jay, Looks like you have a keeper there.
Don
This page was generated in 0.056 seconds.
