WD45 226 ENGINE modified
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 226 ENGINE modified
    Posted: 08 Mar 2013 at 11:48am
Fellows that modify the 226 engine to gain more hp. What changes are made?
If  bore and stroke  were revised what would the new bore and stroke be.
Edited by Moderator - 08 Mar 2013 at 2:59pm
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
CTD03 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTD03 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 2:41pm
That's messed up post.... Or it may just be my (I pod)
Edited by CTD03 - 08 Mar 2013 at 2:42pm
1961 D17
(sold)1968 190xt
Moderator View Drop Down
Moderator Group
Moderator Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Moderator Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 2:59pm
Fixed ya up.
The moderator at any given time may be the forum owner, or a trusted assistant. Your cooperation is appreciated. Thank You
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 3:48pm
Using regular off the shelf parts a WC/WD engiine with 4" bore & 4" stroke is 201 cid. By increasing the bore to 4.125" you are now at 217 cid. Adding the 4.5" stroke WD45 crank to the larger bore now puts you right at 240 cid. Of course the stock WD45 or D17 is the 4" bore & 4.5" stroke combo at 226 cid. For a fairly mildly modified pulling engine I prefer the "Power Crater" pistons for a 170 or 175 that puts you around 7.75:1 compression with the 4.5" crank, but others wanting even more compression like to use WD flat top pistons with the 4.5" crank. Any of these combinations use the same rods, as everything from WC-D17 is the same length. Anything bigger than these combinations require custom sleeves and custom stroked cranks. Good Luck...Kip
HANSEN'S OLD ORANGE IRON. Showing, Pulling, & Going!!
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 4:40pm
4 7/8 bore by 6 1/2 or more stroke.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 6:37pm
 Fred, ......KIp is right on , ignore the panky post.     Gary
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 7:03pm
Kip has it right and this would be a fairly cheap way to get started and you can always do more later.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 8:22pm
You can vo kips way most of us do at first ifs just a waste of money causs if it gets in your blood you will want more and more and each time its more and more money
Ihateillinoisnazis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ihateillinoisnazis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 8:27pm
One day after all the banning and you give us this much ammo to make fun of you with?
English.  ...Type it!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 8:37pm
Ask dr.allis how many cubic inches his is ask.brown how many cubic inches his is. Ask barney how many inches he ran in the antique class. Ask jr crum .Hayden Gibson. Mitch Pankey. Just ask them how many cubic inches they feel it takes to be competitive and go from there. Its only a matter of opinion.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 8:44pm
just ignore him guys...
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 9:40pm
from what i've read, as with most engine builds, you are only limited by your check book and class rules
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 10:26pm
Hopefully we can do that. I'd hate to see the forum pulled, the wrong people kicked off, and posts overrun with nonsense and bs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2013 at 11:18pm
The claim of 4 7/8" bore is impossible, in fact I don't think anyone has done 4 3/4" let alone 4 7/8".
KGood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 7:32am
Our biggest is 4 1/2 bore and 6 1/8 stroke. Used an engine out of an E combine. We had a guy in our old club that went bigger bore. I don't remember what but he said he split two blocks so now he has some sort of tie rods going from side to side. His name is Ira Banter he is brother of the Banter brothers team that pulled multiple engines on there modified early on when not allot of people did that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 8:22am
Use of a deck plate might gain a little, but most Antique Clubs don't allow any deck plate spacers between block and cyl head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 8:35am
Dr you want to see pictures of a 4 3/4 or a 4 7/8 .its possible and in the shop now. I have never lied to you and always appreciated you honesty and opinions when we have spoke in conversation
Edited by mlpankey - 09 Mar 2013 at 8:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 8:45am
Ignore
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 8:51am
Ps don karpells old pulling engine was the first 4 3/4 bore engine i knew of and we all know how many years it was on the pulling circuit. Yes everyone that we do engines for is in hope that their coompetitors ignore me.
Edited by mlpankey - 09 Mar 2013 at 8:53am
arcticcat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arcticcat Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 9:21am
Panky. Mind your own business you dont no what you are talking about
Rod B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 9:24am
I'll bite. So how many cubes does it take to be 50 feet behind in the classic class Mitch Pankey?   How many cubes does it take to be 100 feet behind in the outlaw class Mitch Pankey?
As far as never lied to us, that's a lie also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 9:26am
310 cause everyone else was 400 inches or better 310 can win some but everything has to be perfect.this site crys for the truth but when given truth thwy can't handle it.
Edited by mlpankey - 09 Mar 2013 at 9:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 9:28am
While some people follow pulling forums, others lead them. Take the advice of Dr. Allis or Wi50.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 9:34am
Rod you will be suprised what you learn when you start betting people that they arent 440 inches.i bet that there was no way dons wc running a step down box was 440 inches well when tbe head came off my money left it measured a stroke of 6.25 and 440 inches so you do the math on the bore size if you can. Four people where standing there when the bore was actuallyy measured as well.
Edited by mlpankey - 09 Mar 2013 at 9:37am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod B Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 9:55am
And L Hud kicked you around with much less than 310. Maybe others are much better wrenches than you! Maybe you're a poor gambeling man getting took on your bets. If Wi sent you the flow numbers that'd be another 200 union bucks spent on your education.
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 10:23am
4 3/4 is doable anything over that  the sleeves are very thin. anything can put in. 4 7/8 plus a good size wall thickness is no room. Some guys dream big bore but if it does run its a dream . dons engine is 440 + .
Post Options Post Options   Thanks (0) Thanks(0)   Quote arcticcat Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 11:09am
Panky you dont have any pictures because you wouldn't post and go back to school and take a spelling class
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ihateillinoisnazis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 11:45am
Yes, please post pictures. Also put a caliper or whatever measuring stick you use in the south to measure the bore diameter in place while taking the picture.
cms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cms Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 11:58am
Hey planky how do you know so much about dons motor?  Do you have it now?  Where are located?  Last known the motor went to ohio
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ihateillinoisnazis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2013 at 12:10pm
LOL he's going to come up with a story about how he bought it "just to keep Don honest"
Insert another Plankey lie here... [                  ]
This page was generated in 0.207 seconds.
