D19 alternator
m16ty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Topic: D19 alternator
    Posted: 04 Mar 2012 at 9:41pm
I've been having trouble with my old generator on my D19D. I want to change over to a 1 wire alternator. The only problem is after looking at it there doesn't appear to be enough room to fit a alternator in where the generator is. I know people have installed alternators on D19s. Got any pics or the way to make it fit?
bwp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 10:00pm
I used a 10si GM three wire alternator. Took the pulley from the generator straight off and put it on the alternator. I welded up a small custom mount that bolted onto the block so I had the option of putting the generator back on if I wanted. Didn't even have to buy a new alternator belt, just reused the old generator belt. Clearance is pretty close to the edge of the front shroud, probably about a 1/16 of an inch, but it fits and looks good. I'll try to get a picture for ya tomorrow.
Brad
1962 D19D FEL, 1970 F250 390FE, 1997 Dodge Viper GTS, 1968 Roadrunner in pieces...
Whether you think you can do thing or if you think you can't, you're probably right. Henry Ford
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 9:38pm
Wouldn't it be easier to get the old generator rebuilt??  Usually as good as new for just under $100 around here...
bwp View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bwp Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:32pm
Heres some pictures.  Hope this helps you.  Brad
Post Options Post Options   Thanks (0) Thanks(0)   Quote m16ty Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:48pm
Thanks for the pics!
Looks like that generator bottom mount is different from any of the others I've dealt with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 7:33am
That 7071 3 o'clock version fits in there just right. Its pint size "CS-130" cousin would give you more room in tight quarters like that, but that "SI" seems to fit with a little room to spare. Nice job Brad. Looks great! 3 wire which is what you want on a Tractor, and a nice simple mounting bracket to. Lookin' good!
