Bareback 190xt
2wise4agm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 2wise4agm Quote  Post ReplyReply Direct Link To This Post Topic: Bareback 190xt
    Posted: 02 Mar 2012 at 1:10pm
Anyone ever make a 190xt a bareback? I think I'm going to strictly pull mine and could use to shed a few pounds. I can make a cover plate, I'm just not sure if there is going to be a shaft that will need to be supported, or any other issues. Thanks in advance.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 3:33pm
I have a XT that is almost a bareback.  I has no 3 point or snap coupler.  Since it has PTO, I would have to make a cover w/gasket for the rear housing and take out the shaft.  Could you order a XT from the factory with no PTO like a D-21??
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 3:51pm
Best I can tell by studying the Parts book views, which are lacking at best for a case casting view.  I would say no, because the PTO shaft and seal pass through from the rear oil sump, to the front oil sump.  That would be the only thing I can see.  That being said, I don't know why you couldn't fabricate something by welding up the seal center with some lightweight metal.
Edited by Orange Blood - 02 Mar 2012 at 4:01pm
Still in use:
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 4:29pm
I've seen a bareback 200 so I'm sure the same applies to a one ninety.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2012 at 4:44pm
Shove a chunk of shaft the right diameter into the seals and retain it with hose clamps or whatever to keep it in place....can be done without spltting tractor.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 3:58pm
Rubber expandablel freeze plug worked good on my diet d 19
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2012 at 7:24pm
Is it oil resistant rubber on those plugs?
Wink
I am a Russian Bot
