Ca motor pics
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: Ca motor pics
    Posted: 21 Feb 2012 at 9:47pm
This is what was found wrapped up in the oil intake pipe....
other than that it looks clean and runs great (except the trans problem:)....
Edited by Josh Day - 21 Feb 2012 at 9:48pm
SteveC(NS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveC(NS) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 7:50pm
Josh, that looks pretty ugly allright but what is it?
BTW the inerds look reall pretty! - like mine, but i still had the knock!
It's on the back burner for now but I'll get to it (The elusive "round tuit")
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 9:02pm
plastic, some metal, and hair of some kind. other then that it looks good.I haven't got to run it much since I put the new gasket on since the trans problem. hope to get that fixed in a week or so.
BrettPhillips View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrettPhillips Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2012 at 9:21pm
For all the crud in the oil screen, everything else sure is clean!  Looks like someone believed in detergent oil for a long time.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 6:41am
Why did you take it apart? was there noise or no oil pressure?
Storming Norman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Storming Norman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2012 at 7:43am
From all the crud you have a picture of, might want to take bearing off and clean all the oil journals.   I bought a tractor that had a tick in it, and part of the oil pump had broken, got beaten into a million pieces and a small piece of metal got caught in the oil journal to a rod bearing.   Had to have crank turned.   Had I caught it before I could have saved a bunch of money.
This page was generated in 0.073 seconds.
