honing and ringing ???
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Topic: honing and ringing ???
    Posted: 05 Dec 2009 at 9:22pm
My wc cylinders  have a little bit of ring ridge in them, I am guessing .005 or less. My question is, can I hone these out till they are straight and put new rings in and knurl the pistons to help take up the extra clearance? If the ring gap is to much could I get some automotive .010 rings and hand file them to fit? If I dont go this way, where is a good source for piston,sleeve kits? I see them on Ebay for $350,I am guessing they are oversees made. Has anybody tried them? Thanks for any info,JM
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 9:36pm
I ran my ol D14 for 25 years and you could rattle the pistons back and forth. It never smoked or used much oil. Once I finally put in new sleeves and pistons it had a lot more power. If it is just a show tractor that don't get a lot of hard work it be should fine.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 11:37pm
If the ridge is enough that you can feel it with your finger nail the chances of new ring hitting it is enough to dammage ring or oiston ring land.Use a ridge reamer to remove and hone to a cross hatch with slow stone speed.
 .010 over rings may work but measure bore and size rings individual for each cylinder.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:32am
Jim
Where I live you can get the ridge reamer to use from autozne or ORileys for no charge.  You just have to put a deposit on it and then they return your deposit when you return the tool.
Coke
On the 10 over.  Do you need 10 over in the bore before using them.  I am wondering if the rings are .010 bigger than stndard if measured from the outside to the inside of the ring as it fits in the piston groove.  I know about setting the gap but am wondering if a 10 over in too tight of a bore could bind with the bottom of the piston ring groove even if the gap is set correctly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:42am
a bore that is .010 oversize  has a circumference of 3.14 times that much or  .031 longer. If you bore is .010 oversize, your ring gap would be the original .008 plus .031 or .039  , thats too big, thats why you get .010 over rings and file the end to get back to .008 - .012 ring gap.  That helps to guarantee no blow by.  When you hone the bore you need to do more at the bottom of the bore to get it larger like the top near the ridge. If not, the new big rings will bind at the bottom. Check bore, then fit rings top and bottom to guarantee the gap.  I have done what you said and had .016 ring gap at the top and .007 and the bottom and had success with the overhauls. Pistons can be .010-.012 loose in the bore and still be o.k. , even tho that is wide out of spec. Runs good, no smoke, no piston slap, just might be a horse power or two short. Not bad on a mower tractor.
Edited by steve(ill) - 06 Dec 2009 at 7:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:12am
thanks steve, I think I got it now.
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:34am
JM If you are looking for an engine kit, Call Dan Doc Smith at 309 246 2900. He has kits very resonable priced. He also is on our favorite site HTHS Don in Indiana
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:51am
Actually the oversized rings were made to use with oversized pistons in engines that did not have wet sleeves. A new piston has .002 clearance in the smaller piston sizes. If you are building a high performance engine you would want the piston to not slide down the inside of the bore with a 1/2" wide .003 feeler gage.  At one time you could buy automotive pistons that were oversized by .003 for Chevys and .0025 for for Fords. The oversized pistons jumped to .010 - .020 - .030 -and .040. The cylinders needed to be bored and honed to size for the larger pistons.
A word of caution to those trying to hone off a ridge rather than using a ridge reamer. A flat stone hone will ride on the ridge and down it the cylinder and wash out the cylinder as it removes the ridge which just changes problems from a ridge to a large area down in the cylinder where the rings work. A dingle berry hone will do the same.
To use a .010 oversized ring you would not want any area of the cylinder wall more than .010 larger than standard. If taper exists the .010 rings would want to be would want to be filed to the proper gap at the smallest spot down in the cylinder wall.  To check the gap I press the ring down with a bare piston.
I wanted to have some more pictures than what is at my picture site now but with my problems it will most likely next week some time before I will be able to take them.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 1:04pm
who ever thinks that oversized rings were made to compensate for worn sleeve bores is WRONG in there thinking. file fit rings come oversize so you can file to the ring gap to the required gaps to keep them from butting and yet not have excessive gap causing a loss in comp.blow by performance. Quit doing stuff cheap and do it right  or dont do it at all!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 2:14pm
Which only is neccesary if the sleeve has been worn to where a standard ring has to much gap between the ends.
mlplanky what we end up here is two different discusions. I think there is two rights in this hobby. One is the proper way to rebuild a high performance engine that has a high cost of parts as well as tools that would never be needed again. Higher costs than a lot of hobby rebuilders can afford. The other is an affordable way that the hobby rebuilder can get a well running low usage tractor without buying a lot of expensive parts and tools.
I personally would rather see more tractors running well  even if not up to every spec as the newbe learns more about how the old engines work rather than get discouraged thinking they are totally in deeper than the pocket book can stand. That can be done and has with quite a few on this board. When I read the pride expressed when a fellow starts the engine on his first rebuild, it is priceless. Was it all done to the pros standards? Probly not but why care if it is running well. That pride helps others to try their hand. That in turn expands the hobby so it is still a live when I or us old duffers bite the dust.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 2:25pm
Amen Dick, I like to come up with creative ideas for building a engine that will make it perform well with out throwing gobs of money at it that I dont have. Anybody with money can just go buy new go fast  parts, it is quite different to build with little money and still get performance. Burt Munroe built the worlds fastes Indian Motorcycle 40 years ago out of well pipe and hand made pistons and rods. His record at Bonneville has yet to be beat. That is what I like.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 2:35pm
theys a  big difference in hand made and cobbled.  craftsmen jackleg
JM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 2:50pm
I agree, big difference between cobbhousing and good craftsmanship, some ideas work, some dont.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 2:51pm
You will nver hone them straight and square, but hone them with a dingleberry type hone and because you will still have a tapered cylinder, use standard rings , the end gap of standard rings is the least of your worries  in bores that aren't true. If you can,  find someone to knurl your pistons for a better fit and that will mean you hand fitting to each cylinder  It will by no means be a 100% overhaul but it may tide you over till your budget  for this type of project matches what pankey is willing to fork out. It's your tractor and your money, not his.  Gary
I started out years ago with nothing.... after this divorce , I'll be getting most of it back.........
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:08pm
This is a good post.  I can see both sides of this discusson.
For these old tractors, which usually don't see much hard use, the "good enough" approach is often ok, even if not up to high performance specs.
I feel that just knowing what is right and "good enough" is half the battle.  I'm still learning when it comes to this as well, for the record.  I currently have a junk spare power unit engine that I got with another tractor, and am learning more about engine building with it.  The plan with it is to do the low cost approach, but still checking the specs, and keeping things within, or very close to them if possible.  I don't have gobs of money to throw at this engine, even more so because its not a high priority project for me, but rather a learning one.  We just want to see if we can get this engine, which was completely stuck everywhere, cleaned up and back to working specks and running, cheaply.
On the other hand, I have a 56 chevy 235 for my truck (find my PU post for more info) that I am rebuilding, which is going to be a high dollar build.  It was in rough shape as well, and I am cutting no corners with this engine, because it will be in a truck that will be worth much more than any of my AC's and I feel the extra effort is worth the money.
It's all about the project, what it means to you, and your goal for a finished product, also factoring in cost and time.  Finding that answer is different for each project.  The best you can do is read all you can so you can make educated decisions.
I'd love to see pics and know more when you get time Dick, I love reading about your engine knowledge, I've already learned tons on what to, and what not to do with these old AC engines from you, thank you!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:10pm
garry piston rings bearings and gaskets cost me the same as they do anybody. so why wouldnt you be thorough threw the entire build than to let something like cylinder wear having you reoccur those costs again in a year or so. unless youre going to sell  it off to some unexpecting soul. I dont and will never understand someone skimping on the cylinders when the gasket kit and bearings are more than $300   by the way ring end gap  should be .0045 per every inch of cylinder bore.  cylinder to piston skirt clearance affects ring seal and thats all ive got to say about that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:11pm
mlplanky, you are a talented well trained craftsman. I would hope that you did not think everyone that entered the hobby needed to start at your level.
I, myself not having your talent and knowlege have been able over the years to cobble up many engines of a verity of makes of cars,trucks as well as tractors  and not have a bunch of problems.  I am sure my work would not meet you standards. However I don't think you can find one question I have ask over the many years that I have been posting on the boards asking how to or why does to keep my engines running. You never know, someone you pegged as a cobbler might be someone you might need to as for help when you are getting around with a walker. (:^D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:32pm
I agree with MLP in that on a tractor I would want to "do it once", but like Dick says, not everyone can afford to spend what it might require. I too would rather see someone rering an engine that really should have new pistons and sleeves and have a few $ to fix up some of the rest of the tractor and save it from the junk yard as opposed to letting it go. The more demand there is for replacement parts, makes them easier for everyone to get.
I frequently go back with a standard piston on my collection of small engines simply because either an oversize is not available, or it's just more than I'm willing to spend. The small engines will be unlikely to do more than run with no load, same as a tractor in a collection may only go to a show, parade, or on a tractor ride.
It all boils down to what I remember my high school auto shop teacher telling me once. You can do a 30,000 mile rebuild or a 100,000 mile rebuild. Both will run when finished.
Edited by Brian Jasper co. Ia - 06 Dec 2009 at 3:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:33pm
 Dick youre taking general statements not derected to no one personal . I like you .I like youre post.  the craftsmen to cobbler was about monroe hand making his pistons and rods.  anyone who hands made his products and set speed records is a craftsmen  I gaurantee mr. monroes piston skirt to bore clearance and ring gaps were areas of concern for him. hope youre not to mad to read all of my posts maybe you will see where i am coming from on this. I am no means talented just well tried and tested. they was a statement once i do not know whom to give credit to for it but the quote was the only reason industry needs research and developent is cause of the designers ignorance . that fits me to the tee.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:45pm
Mplanky, you are certainly entitled to your opinion, however, your attitude would stifle a lot of ingenuity and creative effort. Years ago a neighbor kid decided he was going to put a 390 truck engine into a fox body 'stang. Everybody told him he couldn't do it. And worse, his entire collection of tools could be carried in your pockets, with the exception of a four pound hammer. He did make use of the high school fire axe and welder on the oil pan. And he had no garage. He truly was the shade tree mechanic!. But he did it. It looked like a train wreck, but he did it. Beat the snot out of the firewall with the hammer for clearance. put a tunnel in the oil pan for the steering linkage, Etc, etc.
I would rather have ten guys like him, that don't know the meaning of "can't", working for me than ten guys that can only tell me reasons why something can't be done, or isn't right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 4:00pm
lou i dont mean to sound like i am killing ingenuity. I am for ingenuity. if i wasnt I wouldnt own a 226 gas engine with a 4 3/4 bore . that school kid you mentioned thats alot of work even alot more work to take it out and freshen it because it want freshend to start with.  i have been the school kid also alot more time and energy than funds . they are several tractors around that i have just unstuck got them running good at the time and painted them . but now they need engine work and there goes the paint job. and money right down the drain . redoos cost sometimes more than right the first time thats all i was getting at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 4:02pm
   This may be off the subject a bit , butI read some where that Henry Ford was often heard to say , Well lets try it and see why it won't work...... JM, re-ring your tractor and see why it won't work, but I'd bet it will for what you want. The ONLY time I would have a problem is if you tried to pass this off to some one as an overhaul. Gary   PS, I don't think you would do that either..
Edited by Gary in da UP - 06 Dec 2009 at 4:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 4:47pm
mlpanky ole boy I don't get mad at anyone. I don't get my feelings hurt as well. I used to a long time ago before I figured out that getting mad or having hurt feelings was a personal choice and I could choose not to. It really works if you want it to.
I was just trying to wake you to the fact that you might be putting down newbe's that are learning from the ground up. I see I was wrong about that from your explanation. When typing responces I also skip words that I thought while typing that didn't get typing which changed the meaning of the point I was making. That means that it was all just words without meaning. Dixie says that I talk that way also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 4:59pm
well writing and typing isnt one of my strong points either. i guess thats why i enjoy wrench turning over anything else
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 5:00pm
I have been reading close and learning on this subject.  If my D 15 II pops off, makes no noise or smoke out the top or bottom, then I will be happy.  It ran almost that good when I tore it down.
If I don't relseeve and put new pistons etc in it, that will be no problem with me.  I bet it will run great and get off and on the trailer once a year and complete the 20 mile tractor ride in style.  I would never think of "pasing it off" to someone.  It is for me and I could care less about what happens to it when I go to plow the big field in the sky.
I have a JD 420 that was bored and has new pistons et al in it.  It runs about the same as the 8N that got  hone and new rings.
I think "doing it right" means doing what makes the most sense economically to me as long as I get the product I am after.
The bottom like to me is that is will run great, wil not rattle and wheese and serve my needs.
I hope this is not taken as a rant, I just felt that I had to give my angle on it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 6:09pm
Ok lets try getting this back to a informative thread. If you were to look into a it manual for the ring gap for a d14 149 engine it would show that the 3 1/2 stock piston minimum ring gap is .007-.017. IF you use the .0045 per inches of cylinder bore the ring gap would be .0157. which fits in the specs. They are variables. ring gap is for the ring to grow from the heat occured during the combustion process. The distance from the piston top to the first compresion ring land and the compression ratio its self could  have a impact on actually at what gap the ring would or wouldnt but at. More btus for energy more heat produced. I have personally used this formula on file fitted rings in performance applications and havent had any promblems . The calculation is for naturally aspirated engines 3 or 4 thousandth should be added to ring gaps for turbo or boosted engines. All my rebuilds are usually built to find some extra power over the stock . yes it my downfall i am a power junky.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:33pm
ML, have you ever used "Total Seal" gapless rings? I've always wondered about them if they would really hold up under extreme stress. My best guess is they are 2 rings in each groove.
Just curious, would your ring gap formula be the same for a diesel?
Edited by Brian Jasper co. Ia - 06 Dec 2009 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:58pm
My current pulling engine has them . I havent ran it yet . The rings really bite when rotating it . its only one ring per land has a spacer that makes it gapless . you still file fit them for the spacer. i tried to get the childs and albert z gap rings but they werent in production when i need them. if you have text messaging on youre phone .pm me with the number i can send some pics of the build . I am not sure on  the diesel . I am using them on the 400 plus cubic inch 15.1  compression alky wd. naturally aspirated diesel with no more than 16.1 cr yes i would use it . the it manual for a d17 diesel shows top compression ring gap of .008-.016  so the formula stays again barely in allis specs .0163 . turbo should add 3 to 4 more  thousandths.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 9:32pm
i have taken more than one old tired engine , torn it down, did the ridge reamer trick, honed the bottom with a rough hone to take out .007-8 and straighten up the bore. Do a final hone, install new rings (.010 over filed to get a good gap), new gaskets, reshim the original bearings, and lap the valves myselft. You spend $60 for gaskets and $60 for rings on a B motor. I have a couple that have been around 7-8 years. They start on the first roll over and dont smoke or burn oil. I only run 100-200 hours per year with a disc or mower deck. It works, you just have to understand how things work, and what your doing. BTDT.
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 7:22am
JM, if you have less than .005 in your cylinders, ream the ridge, hone the bores, and make sure you have proper end gap in your rings and it will run fine. There are many good points presented above, but in the end, it really depends on the application. Your engine will run at 1300 RPM full load in stock form, and will live just fine. Making generalizations about clearances in engines is a huge no no. Eutectic pistons, cast pistons, forged pistons, RPM, endurance, basic engine charictaristics, and many other things play a huge part in all this, and any experienced engine builder will tell you this. With unlimited funds, I agree, if an engine is apart, make it as good or better than new, but if you are on a budget, there are ways to improve things if it's not too far gone. Total Seal rings are good, but they eat horsepower in race applications, we used to use them in Champ car turbo motors, and they did a good job over the long haul. Dick L. gives good advice, and is willing to share his experiences, both good and bad, listen to what he says, and you won't go wrong, he would be welcome in the garage with me  anytime at Daytona, Indy, or anywhere else.
