Slipping Power Directory 185
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Topic: Slipping Power Directory 185
    Posted: 25 Sep 2011 at 5:11pm
Hi guys,the PD clutch seems to be slipping in both Hi & Low range @ low rpm. If I rev the engine up to 800 - 1000 rpm it works ok. I&T book says to check pressure at 2000 rpm & it should be 290 psi. What pressure should it be @ idle. And can I check psi with gauge @ either A or B socket head plugs on the pto control valve showen in pic. Thanks Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 5:17pm
Sorry about tht over size pic, Try to do better next time.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2011 at 6:15pm
Regulating valve in the PD valve is stuck, remove and polish up and I bet it won't slip any more. You can check pressure at those ports.
