Print Page | Close Window
Slipping Power Directory 185
Category: Allis Chalmers
Forum Name: Farm Equipment
URL: https://www.allischalmers.com/forum/forum_posts.asp?TID=37888
Printed Date: 16 Oct 2025 at 9:56am
Topic: Slipping Power Directory 185
Posted By: automaticdave
Subject: Slipping Power Directory 185
Date Posted: 25 Sep 2011 at 5:11pm
Hi guys,the PD clutch seems to be slipping in both Hi & Low range @ low rpm. If I rev the engine up to 800 - 1000 rpm it works ok. I&T book says to check pressure at 2000 rpm & it should be 290 psi. What pressure should it be @ idle. And can I check psi with gauge @ either A or B socket head plugs on the pto control valve showen in pic. Thanks Dave.
Date Posted: 25 Sep 2011 at 5:17pm
Sorry about tht over size pic, Try to do better next time.
Posted By: Kevin in WA
Date Posted: 25 Sep 2011 at 6:15pm
Regulating valve in the PD valve is stuck, remove and polish up and I bet it won't slip any more. You can check pressure at those ports.
