Allis model names
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Topic: Allis model names
    Posted: 16 Sep 2011 at 7:57pm
This is probably a dumb question but I'm just wondering if anyone knows how allis came up with the names for their models. For example the model u was started in production in 1929 but then they made the model a in 1936. And the wc started production in 1933. So for there letter series how did they decide what to name each model?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 8:08pm
I would guess the U came from the United tractor and the UC is Model U Cultivator tractor. W comes after U for the WC? Pretty wild guess huh?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 8:59pm
   Would it not be a VC then ?
   And the E came before the A, B, and C.
http://www.rumelyallis.com
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 8:59pm
and d comes after c  soo wd and same tractor with different engine with 45 hp so wd45 but it is all a guess
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 9:27pm
Don't forget the Gleaner combines. They read like alphabet soup.PT, A, R, NR, E, F, J, H, T, S, and P-80. Then A/R/B, T, C, E, F, G, K, M, L, N, R, C, A, and now S. Did I forget any?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 9:56pm
E III.  Wait a minute, what happened to E II???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 10:37pm
The WD45 was never rated or tested at 45 HP.
Allis Chalmers WD45 - tests
Allis Chalmers WD45 tractor photo  I&T Manual: Allis-Chalmers B, C, CA, G, RC, WC, WD, WD45, WF
I&T Shop Manual
1953 - 1957
more Allis Chalmers WD45 specifications...
Nebraska Tractor Test 499:
Test Date:July 29 - August 10, 1953
Type:Gasoline 4-speed 2WD
Belt power (max):43.21 hp [32.2 kW]
Belt fuel use (max):3.8 gal/hour [14.4 l/hour]
Drawbar power (max):37.8 hp [28.2 kW]
Drawbar pull (max):5,441 lbs [2468 kg]
Max pull gear:1
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2011 at 10:54pm
   The 45 is 45 engine HP. 43.21 is the belt HP.
John (C-IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John (C-IL) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2011 at 8:23am
The 45 stands for 4.5 inch stroke.
arrowcreekfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote arrowcreekfarms Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2011 at 2:02pm
Like my teacher said I before E except after C never made sense so I never questioned it, I guess it works out haha
1972 200 diesel, 1966 190 Gas, 1962 D-15 Gas w/ #15 loader, SC 3-16" Plow, SC 8ft disc, SC 2 Row Cultivators, 500 Series 4 row Planter
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2011 at 4:55pm
Maybe they had a dartboard with the letters on it?
This page was generated in 0.344 seconds.
