Long sitting Allis |
Page 12> |
soundman502 ![]() Bronze Level ![]() ![]() Joined: 07 Aug 2011 Location: Spencer, IN Points: 23 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Aug 2011 at 10:19pm |
I'm about to bring home my grandfather's old
I'm familiar with soaking the cylinders in ATF and giving them time and nudges until they release, but I'm sure this can of worms still hasn't fully opened yet. My plans are to attempt to restore it for show and minor house work, and in doing so preserve a piece of my families history. Where can I find some documentation on what levers do what, and wiring diagrams and such? I'll have the serial number to run soon so I can get the year info, but I'm trying to study up before she gets here. Will post pictures soon. Thanks, Scott **Edited because I found the serial number on the back, and it shows as a WC.**
Edited by soundman502 - 10 Aug 2011 at 8:13pm |
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Scott, check ebay for an operator's manual, many reprints and a few originals can be had for cheap. You might also want to get an I&T shop manual, available at many farm stores like Tractor Supply, Runnings, Mills, etc.- it has very good illustrations and instructions for disassembling and repairing anything on the tractor.
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4942 |
operator manual,believe vendors on here sell them.
Bill types faster than I do.Fat thick slow plumber fingers Edited by Pat the Plumber CIL - 08 Aug 2011 at 10:30pm |
Scott, go to the top of this page and click on Allis Store then click on manuals. Darin sells these and they are excellent quality reprints and you help support this site.
Awesome guys, I'll check into Darin's manuals and keep reading here.
I've been waiting for years to finally get to bring this thing home, and I'm probably like a kid on Christmas Eve waiting to get it here. Just looking forward to getting to work on it. I get a strange kick out of getting down and dirty on old stuff.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12006 |
Nothing like saving a family airloom, especially when its an Orange tractor that says Allis-Chalmers on it!! Darin's manuals are the way to go there. If you need any electrical diagrams, info, a wiring system, or any electrical parts for your "new" 45, we can help you out with anything needed on board that Tractor. Good Luck! They are a lot of fun to restore, and its a GREAT hobby!! The problem is, once you do one, the "Orange bug" bites you and you need another to restore for your "fix". And then other, and then another...Don't ask me how I know that!.... Hello, my name is Steve Barbato and I'm addicted to ORANGE.... LOL!
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6078 |
Scott- whatever you do, keep us updated on the step-by-step, and post pictures frequently. Most of us are working on these buggers, but there's a few guys who, for some reason, can't... and we ALL live vicariously through our comrades challenges.
Oh, and if you post pictures soon enough, we'll tell 'ya what NOT to do, before you do something we wished we wouldn't'a done ourselves. And give 'ya little tips like mixing up equal quantities of ATF, kerosene and acetone to make your own high-potency penetrating oil... and the fact that the pistons are usually 'dished' design, so it takes LOTS of penetrant, and if she's really stuck, you can bust the ceramic cores out of the spark plugs, weld on some 1/4" pipe, and thread on hoses to a regulator and put a little air pressure on the cylinders to help break her free. Most common spot to get a visual of a broken block, is on the left side, below the carbeurator. When they split, they'll typically SHOW it about 2" above the crank pan flange. IF they're cracked, you COULD fix it... oftentimes guys did by a variety of methods... brazing... arc/flame welding, silver-soldering, or in the case of my '50 WD, they drilled and tapped about loozanteen holes around the outside of the crack, covered a piece of tin plate with roofing tar, and screwed that sucker down. Of course, it would've worked, but when the block froze, it also cracked some of the internal webbing, so the cylinder sleeves wouldn't seal against the block, so it leaked internally... But no fear... decent running engines aren't hard to find, not incredibly expensive, and they're easy to change. These engines (and the tractors in which they lived and worked) were designed for in-frame rebuild... pop off the head and pan, break the rods loose, lift out the pistons and cylinder liners, drop in new stuff, new rod and main bearings, and button it up for another 40 years... Most expensive part of a home remodel, is the kitchen and bathroom. Likewise, most expensive part of a tractor revival is tires and engine. First thing I always look for, is a way to ROLL IT AROUND. If the rubber is good enough to hold air, then you've made it to the first step... working on flat-tired tractors SUCK, 'cause you can't jockey 'em in and out of the shop. I bought a set of old steel wheels, unbolted the cleats, and put 'em on my current project, just so I could wheel it in-and-out. Nice thing is, steel is really easy to work around- you can see through it, even get wrenches and arms around it. When I'm done with everything else, then I'll make a rubber investment and get it burblin' down the road. Then I'll move the steels to the next project, or clean 'em up and keep 'em on hand for someday when I wanna take an oldster to a show. I need to put a bumper sticker on my car that says "The more I work on modern cars, the more I love my Old Tractors!" |
Kcgrain ![]() Orange Level ![]() Joined: 24 Sep 2009 Location: Wisconsin Points: 794 |
If your going to buy a repair manual dont waste your money on an IT pay a little extra and get the one from Allis Chalmers you will be much happier, and it also has machine updates in it so if something changed internally it will tell you what. The IT is cheaper but the info is vague, and if your not a mechanic its sometimes hard to understand.
The tires on this one are SHOT! I think when it was rolled into its current resting place, they were flat, and they are shredded now, front and back. But I don't have a shop to move it in and out of, so she'll sit in about the same spot for a while.
DaveKamp - What kind of steel wheels can I put on this old girl? I thought about getting those since rubber is so stinking expensive. I'm new to tractors overall. I've run them, and helped work on a few, but it's been years ago. Thanks for all the input guys! I can't wait to get a full assessment of what I'm getting into.
John WV ![]() Silver Level ![]() ![]() Joined: 30 Oct 2010 Location: bunker hill wv Points: 273 |
soundman I brought a wd45 years ago. I don't know how long it set out side but the boot at the gear shifer was bad and had water in it . all the gears in tranny and rearend was shoot full of rust and bad pits .I wish you luck in getting her fired up
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
You've got my curiosity going. Why do you say assumed cracked block?
Dusty
Dipstick In ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Remington, In. Points: 8602 |
I own some IT manuals and just love them. They take you step by step through all the easy stuff up to the point where you need to know something and just drop you FLAT! Just a little better than a comic book.
I was told that the block was cracked, but no one has been able to show me or tell me where, so until I see it, it's an unknown. I'll be bringing it home tomorrow hopefully if the weather holds out here, and I'll have tons of pictures to post then.
My family farmed with this one until it was parked, so it was maintained in it's operational times, but I know no one has ever tried to fix it since, so it's just a bag of unknowns. I appreciate all the interest here, and the help so far!
LouSWPA ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25196 |
I'd get a good woman for the housework!
I am still confident of this;
I have one of those, but the WD is for the stuff she won't do ;)
Orange Tractors ![]() Silver Level ![]() Joined: 13 Sep 2009 Location: Butler, MO Points: 172 |
Scott,
I have seen a tractor (MF-65) with a cracked block that would leak coolant when cold; but once the engine warmed up, the cracks quit leaking. Quite the pain to actually use because it always seemed to me that it was a fine line between getting the block warm enough to seal and getting it so hot that it would seize. Check the oil pan for water first.
My WD sat from a couple of years before Grandpa went into a nursing home until a couple of years after I retired from the Navy, about 16 years as close as I can figure it. I couldn't turn it over with the hand crank, the rod through the front pedestal was siezed, (the tractor had lived with a loader on it ever since Grandpa bought it when Dad and my other Grandpa quit farming in '65). It turned over fine with the starter though.
I had a little bit of water intrusion through the shifter boot, but the gear oil had left a thick enough film that none of the transmission gears were damaged. My only real problems were that someone had helped themselves to the generator, dash and the oil pressure guage. Don't you just hate thieves?
My magneto also wouldn't work, I used the distributor and a few other parts from the parts tractor I bought. It was cheaper to buy a ratty WD for the parts I needed than to buy some off brand and replace the implements I already had.
Good luck on the tires, hopefully your rims are salvagable.
Robert
Edited by Orange Tractors - 09 Aug 2011 at 10:33pm |
There are soft plugs it the head under the tappets cover. They often rust out/get pin holes in them, allowing coolant to get in the oil. It could be that is what happened, and someone thought there was a crack somewhere. Good Luck, Dusty
Dave Richards (WV) ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Tried to load these yesterday, but the picture loader was down.
This should get you started Dave ![]() ![]() |
Scott- I don't know if there were any 'factory' steel wheels to fit the WD-45- it's standard wheels are spin-out rims with rubber tires, and the WD45 used a different bolt pattern (more bolts). The prior models (WC) STARTED with steel, and in the late '30's went to rubber (kinda a landmark thing that Allis Chalmers did). After rubber ag tires came out, many steel rims were torched off, and steel rims were welded on, then rubber tires and tubes mounted in their place. During WW2, steel came back a bit because of war material rationing... but after the war, rubber went back on. By the 45's time, everything was all rubber. The way you'll FIND steel, is just by coming across the unique situation of someone having a set that they made... mebbie some steel from another model where they drilled new holes or made some sort of adapter plate. Lemmie ponder that- mebbie I have enough materials and info here to make some adapters that'll put WC steel on a WD hub...
If your rims are shot, a better method might just be to saw the bad rubber off, and set it down on the rims, and when you get back to it, put on a set of better wheels/tires on it later. |
Thanks Dave. I don't know if the rims are shot the rubber is for sure, but who knows. There's a tractor bone yard about 30 miles from me that I'll be visiting soon.
Go gently with forcing a stuck engine to move by the crankshaft. That can take more force than the connecting rods can push and they will buckle and bend. That's not progress. Best to work with pan and head off and jack out piston and sleeve and maybe separate them with a hydraulic press pushing on the piston. You may save the rod that way, but once you have the head off you can see what the pistons have for crud above them to make them hard to move up. Its almost sure a couple valves have been open all the parking time and humidity as well as mouse urine has been able to circulate in those cylinders to leave significant rust. Stored inside there's a chance for much less rust.
Gerald J. |
Went out to retrieve Ole Red, and she won't come willingly. Went out with a trailer and a winch, but no budging. I'll have to take another tractor out there and see if I can coax her out. In doing so though, I have tons of pictures that I took of her, and my serial number info, which despite my previous information of it being a WD45, it is in fact a WC. SN# WC145071 I don't know what that means yet, but I'll soon find out.
As for the "crack" in the block, it turns out to be a hole big enough for my to fit my fist into. I don't think it started that way, because I see remnants of JB Weld around the edges, but I can see clean into the cylinder wall. I'm wondering if this block is repairable at this point....
If I've decoded the SN correctly, it would appear that I have a 1945 A.C. WC Can anyone confirm this based just on the SN? I'll have pictures up very shortly.
You have a 1945 WC. A decent block should not be hard to find. Depends where you are going with the tractor, you could buy a running engine and drop in it if you want it going to do some work or play. If you want to restore it later that might be the best choice, give you time to find other needs or wants for the finished product.
Rfdeere ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Idaville, IN Points: 3283 |
That serial # would make it indeed a 1945.
http://www.rumelyallis.com |
For those that have looked at the images, #7 shows the hole I'm referring to in the block. Is that too much to fix? I would love to hear it run soon, but the main focus is restoration, so if possible, I'd like to keep her all original :/
We had a 39 WC on our farm when I was younger.Raked and crimped a lot of hay on it back in the day.
Not too bad for sitting out so long,have seen a lot worse brought back to life. Mechanical lift is a plus. Whats the story on the planter in the weeds next to it? 4 row? snap coupler? Are both marker arms on it? |
The planter is a 4 row with both arms. We have a harvester sitting right next to it. I figure if I can Red fired up, I might be able to pull those out too. I don't have the land to use them, but it's a shame to watch them decay in the fence line.
I'm not sure about the coupler though. I think my grandfather bought them for use with the McCormick Farmall H that he bought after Red. It's sitting in a corn crib about 100 yards away, but I don't think I have a chance at getting that one. It still runs :)
If you get a chance take some pics of the planter and harvestor.Love to see the stuff back in the weeds.
Thanks for posting pics,keep us informed of your progress. |
Page 12> |
