wd dual wheel spindle
kxt710 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kxt710 Quote  Post ReplyReply Direct Link To This Post Topic: wd dual wheel spindle
    Posted: 26 Jul 2011 at 11:40am
Hoping someone can help. I purchased a WD a few weeks ago in rough shape. I got her running so time to move to the bad front spindle. I have an extra whole front support that came with the tractor so I thought the easiest corse of action would be to change the whole horizontal spindle and block assembly. According to the manual all that was needed was to remove the cap screw, washer, shims and spindle block retaining screw - no luck couldnt get it off. Next I decided to just take off the one horizontal spindle by removing the retaining pin and using a puller. again no luck.
Questions - to remove whole horizontial spindle block assemble is there something else I need to remove?  Is there another trick to remove the horizontal spindle itself?
yjanks KT
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 11:42am
   Are you trying to remove the steering box as well?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kxt710 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 12:24pm
no I was hoping to just remove the whole spindle block or just one horizontal spindle to keep it simple if thats possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 12:54pm
   My guess would be that the main shaft going down through the spindle block is mushroomed over a little on the bottom end, or the shaft is rusted/frozen to the spindle block.
   It may be easier to take the steering box off with the spindles, so you can flip the whole assembly upside down and work on it that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kxt710 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2011 at 2:39pm
Thanks - I was hoping to avoid removing the steering box as a whole. I could replace with the spaire I have but didnt want to get into that. The spindles I am trying to remove are currently on my spaire.
I am thinking the spindle block is froze to the shaft but want to make sure there isn't another nut someplace I need to take off.
