D19 diesel changes ?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Topic: D19 diesel changes ?
    Posted: 31 May 2011 at 7:37am
   Were there any factory differences / changes / updates made to the D19 Diesels from 61-64 ?
Edited by Rfdeere - 31 May 2011 at 7:39am
http://www.rumelyallis.com
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 7:42am
Some changes were made to the pistons/cam/head starting at engine# d01499 and up. Other than that she stayed pretty much unchanged
1968 D15D,1962 D19D
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 7:47am
There were also some changes in hyd. control valves.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 7:49am
   Thanks Don ! Did those changes increase the horsepower, torque or any visible differences ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 8:23am
Nope, Mdae for easier starting with less smoke.. Head casting was also supposed to be less prone to craking
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 3:40pm
   Thanks, again Don. So what were the changes to the hyd. valves ?
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 4:13pm
Later D19s had self-canceling spools. Instead of the lever staying the raised or lowered position, they would return to neutral.  The valve stack has smaller levers and round knobs, not the rubber handles.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2011 at 9:29pm
   Thank's Chad ! You wouldn't know at what serial number they changed the valves, by chance ?
This page was generated in 0.060 seconds.
