Model C Engines
boilerrepairman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerrepairman Quote  Post ReplyReply Direct Link To This Post Topic: Model C Engines
    Posted: 29 May 2011 at 11:53am
Thanks for all the replies to my other post. Great info. How does one tell which engine is on your model b? I've looked and either I'm not searching right or just not getting it. can anyone shed some light or crack me along side the head to make me understand. Thanks folks.
1938 Model B 3271
Former owner of 1939 WC
Proud Veteran US Navy 1985-1994 GSM1/E-6
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 12:35pm
Depending on the year it's either a BE or CE motor. The BE motors have the serial # on the back in the center above the bell housing, kind of hard to see sometimes. The CE has the serial # on the left side flange where it bolts to the bell housing, very easy to see unless it's covered in rust or grease. If the tractor serial # next to the shifter is about 64501 or higher it should have the CE.
Post Options Post Options   Thanks (0) Thanks(0)   Quote boilerrepairman Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 1:10pm
Ok next question on the engines. Since the displacement on the engines changed with models and the bore i think changed to. (Correct me if i am wrong please) When you rebuild the engine, no matter which model engine block, the new sleeves will work in the block?
1938 Model B 3271
Tedin NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tedin NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 1:17pm
Yes that is correct, new sleeves will work in old block
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:53pm
All model C tractors had th CE engine according to C.H. Wendel. Bob
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 9:54pm
Lonnie, my 42 B  with the BE engine, the number is on the flange    the tractor number is B 56xxx and the motor number is BE 58xxxG
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2011 at 10:41pm
John, that is interesting, we had a discussion about serial # placement a while back because I have a CE engine with the # on the back where the BE should have it. Thanks for the info.
