6080
walkerb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote walkerb Quote  Post ReplyReply Direct Link To This Post Topic: 6080
    Posted: 20 Apr 2011 at 7:33pm
Going to look at a 6080.Any hints as to what to look for or opinions on this model would be gratly appreciated
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 7:47pm
what is your intended use?
Personally I think they are great tractors. Issues is the Engine thrust bearing, PTO level if left to the rear could cause trouble, PTO engagement lever would sometimes freeze up (rust)
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote walkerb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:30pm
Tractor will be used for everything ,work ground,plow ,cut and bale hay.Am looking to get cab and air and get out of the sun,
Post Options Post Options   Thanks (0) Thanks(0)   Quote walkerb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 8:32pm
What is the thrust bearing problem and how do you detect and cure it
lars 60 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lars 60 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 10:12pm
seems to me like maybe the 3 point might be suspect, some models had just one small lift cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 10:44pm
Lars is incorrect.  The small lift cylinder is a helper cylinder that works in addition to the main one in the rear housing.  This was one of the differences between the 6060 and 6080.  Personally I find the 3 ph on mine to be quite rugged and never had any problems lifting anything.  Overall, it is a powerful, economical and comfortable tractor.
rbaggett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rbaggett Quote  Post ReplyReply Direct Link To This Post Posted: 20 Apr 2011 at 10:58pm
Just make sure it has the external bearing and plate mounted on the front of the engine on the crank shaft pulley.  If it has that it should be ok but if not you probably don't want that one unless it is mighty cheap.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 7:27am
I was thinking the latest 6080's didn't need the external bearing. They had the heavier internal bearing. The external bearing fix was a stop gap until the redesign. You have to go by the engine serial number.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 7:41am
Who has the serial number list for the engine fix?
Did the 6060 ever have the heavier design from the factory?
Charlie
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 8:05am
I think the orange bible (Norm's book) makes note of a 6080 serial number break for turning radius chnages and engine updates which I assume includes the thurst bearing.  I am just guessing that the 6060 never received the updates as it was replaced by the 6070 by that time?  Mike
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2011 at 12:10pm
Our neighbor has one and they say it is the worst AC tractor they have ever owned. It has had major engine and transmission problems numerous times and is pretty light according to them. They stated that they wished they had kept their 185 because it was more reliable. All the tractor has ever done is plant , feed and hay work and never done any heavy tillage ect.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 8:51am
Dad and I have one, it's got 7000 hours on it and it's one of our favorites.  That 200 industrial engine in my opinion is one of the best engines Allis built.  I am in the middle of putting a clutch in it but i think 7000 hours on a clutch is not out of line.  I think it is a little light for heavy tillage but it's great in the hay field and i know a guy that pulls a 21' 490 IH disk with one and has for years.
KY, what kind of maintenance does your neighbor do on his equipment and what do the rest of his tractors look like?
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2011 at 2:11pm
Really good actually. It recieves great care. I guess they got a "lemon".
