Calcium Chloride
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Calcium Chloride
    Posted: 21 Feb 2011 at 9:55am
Is there a way to make your own Calcium Chloride for insertion into tires?  Can you buy it?  Any cost difference between Calcium Chloride and any new stuff that is out there?  What IS out there to replace it?  Thanks
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:58am
windshield washer fluid,beet juice, stick around more will answer wwith more
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:00am
If 'road salt' is calcium chloride, maybe talk nicely to the local road crew for some 'leftover' or 'spilled' salt.....
Would water softener salt work just as well ????
Jes thinkin out loud...
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:19am
Calcium chloride is the modern road salt. Softener salt is usually Sodium Chloride though sometimes Potassium Chloride (potash) is used. After seeing what Calcium Chloride did to a decently painted tractor when a tire split and pinched the tube on the inside sidewall, I won't use any of these again. Besides the tractor plowed better with the empty new tires than it did with the old worn tires.
Many a tractor rim has been eaten by minute CaCl leaks around the valve stem.
Beet juice sold commercially as "Rim Guard" seems to work decently without freezing, though I don't think its as heavy as CaCl and its harder to find and costs more. Winter rated windshield washer solvent has a following because its easiest to find in a big box store and at least as heavy as water without doing damage to the tube or tire from freezing and doesn't cause instant rust like spilled CaCl.
To get any into the tire, you turn the tire with the valve stem up and attache a gadget made for the purpose and hook up a liquid pump. You have to pause the pumping at intervals to release the air pressure and you generally stop with some air left in the tire so it can still flex.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:25am
Tractor tire dealers sell CaCl flakes in 50 lb bags.  My first cousin has a small tire business and I buy through him...something like $16 or $18/bag.  Rock salt is like regular salt (NaCl) and won't protect from from freezing like CaCl which has a much lower freezing point in a solution.   You can buy pelleted CaCl ice melt but it takes much longer to dissolve into a solution than the flakes.  It's also usually higher priced by about $10 per 50 lbs if you buy it retail.  Buy some 55 gallon plastic drums (the ones you can remove the whole top lid so you can dump the bags of flakes in) to mix it up.  You can measure in how much water you need for each tire using a 5 gallon bucket.
-20 degree windshield washer fluid would work depending on your area.  It's a little hard to find places to buy it in bulk (55 gallon drums) but industrial chemical distributors may have it.
Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 10:35am
you can buy bulk fasher fluid, check with trucking company fleet as they have source or oil supplier should line you up with someone.
 Chemical supplier for the cal clo flakes or sometimes farm supply.
Used anti-freeze also works. Could see if you can get alcohol from local source and mix with water also to ratio for lowest temp in your area.
 Fleet Farm might have is or can get bagged ice melt by pallet there also , might get it on clearance as we arent getting any more snow ... LOL
dannyraddatz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 11:38am
Found this one call rim guard.
here another for ballest
Danny Raddatz
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 11:45am
Methanol Alcohol works real well. Not as heavy or corrosive, but still a great job. HTH Tracy Martin
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 12:13pm
we use magnesium chloride. It comes in flakes and you just mix it up.
Don't know where the farm gets it from but this is what it is.....two bags to a tire I believe for the Farmall M sized.
http://www.meltsnow.com/products-dry-magnesium-chloride.htm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 12:31pm
For a cheap way, go to your local auto repair shop and collect used antifreeze. Pump it in and forget about it.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:01pm
I priced swapping my tires to some better WD wheels.  Mine are loaded with CaCl.  The tire dealer would take my dispose of my CaCl, but if I wanted something different installed, that was up to me to have available for them to install.  I think without anything other than CaCl, it was almost $300 per tire to hire the swap!
Greg Kroeker
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:29pm
Ted,  If you were further south - like AK, South MO, TX, and the like - you could use a few handfulls of table salt.  That would keep the entire tire from freezing and if it did you could break it by hitting the side with a crowbar.
We had a fellow who worked for us from TexArcanna(?) AK and that's what he used in Fords.  Worked well.  However, WI is too far north and far too cold .
Good Luck!
Bill Long
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 1:46pm
TSC has an install kit $10 to $15 bucks.
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 2:11pm
You can load your tires without apump. Mount a barrel on a stand so the outlet is higher than the tire valve stem get a adpt. [hose to valve stem ] tractor supply has them.  Put a valve on the barrel set the tire valve stem at 10 or 2 oclock  with no weight or air on tire , mix 5 lbs. cal - clor. to agal. of water, hook a hose  to the adpt. & barrel turn on will fill tire & burp its self, will take a few hrs. to fill. Ask tire man how much your size takes [ 11-2 - 24 takes 20 gals ]
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 3:28pm
Called Dow Flake around here. The chemical reaction it gives off as its being dissolved in water makes it heat up.
Edited by DonDittmar - 21 Feb 2011 at 3:29pm
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 3:49pm
My tires are 14.9 x 28's.  Is there a way to calculate the amount?  Should I re-use the cacl that is in one of the tires?  I don't know how old it is?  The other rear tire doesn't have any in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:00pm
Ted - you can reuse the old stuff if you like.  As far as how much here's a chart:
http://www.firestoneag.com/tiredata/info/info_hydro_2.asp
Big thing is to replace the entire valve core's every two years.  That pretty much eliminates any issues with leaking.   Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:00pm
The old cacl works. It doesn't age, just has to be pumped out and a tire dealer used to handling it has the tool for that. My MF tractor manual mentioned how much CaCl it could hold and how much weight that added and farm tire handbooks like on line from Titan, Firestone, and Goodyear have tables of that.
Gerald J.
Kurzy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kurzy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:06pm
I couldn't stand all the damage from fluid in tires, so I removed all fluid. Bought all new tubes, aired up and started buying weights. I got twelve plus tractors and did them all. Never been sorry, now I can sleep at night. LOL
Kurzy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:13pm
I should add that if you reuse the old stuff you won't know for sure how concentrated it is.  If you pump it out split it between two 55 gallon barrels (one for each tire).  Then add more water to each barrel to match the chart for your tire size.  Add equal amounts of CaCl flake to each barrel and wait for it to dissolve.   Start with about half the recommended amount of flakes and see how it does.    If the flakes pile up on the bottom and don't dissolve you've reached the max saturation point.   If you reuse your old stuff and it was the correct concentration about half of the amount should work out about right anyway.  Mike
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Sheridan-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sheridan-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:25pm
We installled winshield fluid with a swamp coolor pump.  It worked very good and is quiet cheap . A pump is less than $10 dollars, winshield fluid is about $1.50 a gallon.
HANSEN'S OLD ORANGE IRON
We show, pull, & go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 4:32pm
I have searched the web for about an hour looking for a rear tire weight system.  It mounted inside the rim and gave you weight without fluid.  Has anyone seen this product?
Danny
Danny Raddatz
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:31pm
You get more CaCl2 per pound added if you use Peladow instead of Dowflake.  OxyChem formerly Dow makes a 90% and a 94%  CaCl2 pellet flake is only 77%-80% CaCl2.   The 94% pellet is smaller diameter and the most dissolvable. The 94% pellet is made with the intent the that the end user will be dissolving it. If CalCl2 is promptly washed off with luke warm water corrosion is not a issue.  Another bonus is the Dowflake and Peladow are American made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:32pm
Danny, the only thing that I could find for you is this:
http://www.jamesriverequipment.com/details/Agriculture/7730-Tractor
Doesn't help much though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote dannyraddatz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 7:56pm
Thanks Ted,
If I ever find it I'll post it.
Danny
Danny Raddatz
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 9:09pm
I use Propylene Glycol... RV Anti-freeze.  I visit the local marinas about a week or so after they've stopped winterizing boats... they usually have a pallet or two in 1-gallon bottles leftover, and I buy it for a few pennies over cost.
Propylene Glycol is non-toxic, so if you spill it, or puncture a tire, you won't poison children, farm animals or toxically contaminate your fields and well.  Not as heavy as some things, but it'll do the job nicely.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2011 at 11:00pm
Wash it off? How fast? My tractor rusted in a minute or two after it was sprayed with CaCl from a pinched tube in a split in the tire side wall. Didn't take hours or days.
Gerald J.
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 6:45am
I use an old gear pump that I put on the tractor pto to pump the liquid in and out of the tube. It was used on a field sprayer and I put pipe to garden hose fittings on the pump and just switch the hoses on the pump to reverse the flow. Rinse the pump out with water and put oil in it when it is dry and you won't have a rust problem. I also put extra wheel weights on the tractors instead of calcium and water, no rust!!
Italy Hill Produce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Italy Hill Produce Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 7:05am
Another thing to consider, pound for pound, solid weights mounted on the rim, or on the tractor give you more traction than filled tires.. though if you have a loader you might want both ;)
With the weight on the rim instead of in the tire, you get a better tire print.. It is also better for the tubes/rims etc. and it is a one time expenditure...
We are working on switching our old farm tractors over to wheel weights, even though my dad has been running calcium in the tires since the 70's... Our old tractors are getting to the point where when they need tires, the rims are pretty shot too... If we switch over to pie weights the tires and rims will last longer...
Jonathan
G tractor and an All Crop 66
Also Kubota MX5100F and M9540HD12
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2011 at 9:47pm
tucker is the one i agree with,i have used prestone in all my tractor tires with no problems.napa sells an adapter for this procedure
This page was generated in 0.144 seconds.
