Early B question
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: Early B question
    Posted: 10 Feb 2011 at 10:55pm
After seeing Gary's great looking 38 B I have a question. What is the hole in the right front of the toolbox for? If they hadn't made a B with electric start, you wouldn't need a place to run the battery cable out to the starter. I never noticed if my 38 has that hole. Maybe it's just to make sure mice can get in the toolbox to pee on your tools.
Edited by CTuckerNWIL - 10 Feb 2011 at 10:56pm
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 11:24pm
isnt that hole used to adjust the steering box ?  isnt there another hole below that for the battery cable?
Edited by john2189 - 10 Feb 2011 at 11:25pm
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 2:27pm
I've got a '39, and that hole lines up perfectly with an adjustment screw in the steering gearbox. Agree with above; I think that's what it's for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 2:46pm
Well that makes sense then. I guess I never tried to adjust my B's steering gear or I might have known that.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 4:43pm
Charlie,  Don't be in a rush to adjust the B steering gear.  Getting those three eccentric bolts in place gave me a pain.
Good Luck!
Bill Long
ps:  Could the hole be from a later model B with the hole for the starter wire?
       Good Looking B.  Does my heart good
GA-IN-TEXAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GA-IN-TEXAS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 6:44pm
THE HOLE IS FOR STEERING BOX ADJUSTMENT, AND BILL YOU ARE RIGHT IT IS A PAIN TO GET IT ALL SET BACK RIGHT, BUT IT IS WORTH IT TO NOT HAVE A LOT OF SLACK IN STEERING WHEEL. (--NOT A HOLE FOR THE STARTER WIRE--)
