D-17 Series 3 Value |
Zyta
Topic: D-17 Series 3 ValuePosted: 09 Feb 2011 at 4:49pm |
Whats the value of good running straight tractor with good tin work Series 3 with power steering.
Did all the series 3's have power steering? did a series 17 have any advancements over the previous series? can add factory three point hitch off later series 17's or any other later Allis. Appreciate your feedback.
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Posted: 09 Feb 2011 at 5:13pm |
I sold my Grandfather's 1964 in 2007 with the plow for $4,000.00 The tractor was very nice but I always thought that was top dollar for the set, it had power steering.
wheatbreeder
Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 581 |
Posted: 09 Feb 2011 at 5:15pm |
Power steering was an option series 4 is the same as a 170
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4981 |
Posted: 09 Feb 2011 at 5:17pm |
I believe that when the Ser III came out Power steering was standard,have never seen a Ser III without power steering.Our 59 Ser I we had on farm as kid is only D-17 I ever saw without it.
Do not believe a factory 3 pt off of a Ser IV will bolt on a Ser III or earlier.Different rear end and hydraulics.All series before IV have to have an aftermarket setup. Edited by Pat the Plumber CIL - 09 Feb 2011 at 6:35pm |
Pat the Plumber CIL
Posted: 09 Feb 2011 at 5:19pm |
Learn something new every day.Never saw a newer D-17 without PS but Wheatbreeder if you say so.Sure would have thought it would be standard.Who would order a 170 without it?
Zyta
Posted: 09 Feb 2011 at 5:53pm |
Thanks good information. I thought I had heard the back side factory three point of the later series would fit. So does a series 3 have live PTO or again is it just by uitlizing the hand clutch?
Pat the Plumber CIL
Posted: 09 Feb 2011 at 6:17pm |
Ser IV has live hydraulics but the PTO is the same as earlier ser.
CTuckerNWIL
Posted: 09 Feb 2011 at 6:20pm |
All 17's have live PTO, none had independent PTO. Claus, I remember when you advertised that tractor on the old forum. I sure wish I coulda come up with the coin at the time.
Claus
Posted: 09 Feb 2011 at 7:16pm |
This is not true, the Series IV still on the farm has a power steering pump, my Dad's white strip 170 drives the power steering from the side hydraulic pump. My black stripe 170 drive the power steering from the front hydraulic pump. |
wheatbreeder
Posted: 09 Feb 2011 at 7:33pm |
I stand corrected I might all series 4 had power steering as the 170 is the same as series 4 with new tin
Morley |
Posted: 09 Feb 2011 at 8:32pm |
I have a piece of D17 series 4 literature dated September 1964.....Optional equipment: Deluxe seat.....Power steering.....Operation meter (tach)....Air filter indicator.....horn......3-spool hyd valve.........break away and non-breakaway hyd couplers.........remote rams........front end weights......front and rear wheel weights......many different tire sizes. I too have never seen a series 3 or 4 without power steering or a cushion seat or a tachometer, but they were an option !!!!
wheatbreeder
Posted: 09 Feb 2011 at 8:59pm |
thanks Dr Allis
power steering was an option on series 4 and mostly likely series 3.... probably by that time all tractors came with ps so the 170 came ps and the live hydraulics Morley
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 09 Feb 2011 at 10:10pm |
The difference in power steering between D17 and 170: D17 is a power assisted mechanical set up. 170 is fully hydrostatic - no mechanical linkage. We kinda got off topic about the Series III. If the tractor was really nice and original, I might offer $3500. |
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 09 Feb 2011 at 10:58pm |
To answer your Series III power steering question, the answer is yes it was an option, because I have one with manual steering. Series III Diesel, with single front wheel. Thanks Rich
ac45
Posted: 10 Feb 2011 at 8:07am |
Ive seen a series 4 with no ps, It was on a local farm auction 20 years ago, it was a cherry, we were going to buy it untill they went o sell it and started it and I walked up and grabbed the wheel , and nothing happend, we went over and looked at the engine, and no ps pump or anything, I couldn't beleive it , cause it was a late model one too.
Jim Lindemood
Joined: 22 Sep 2009 Location: Dry Ridge, KY Points: 2569 |
Posted: 10 Feb 2011 at 9:47am |
Have to agree -- value around here for a decent looking / running d-17 III is around the $3500 mark -- can go up with additional implements, and if is real close to the buyers location.
