2wd 6080 frontend
allis6080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Topic: 2wd 6080 frontend
    Posted: 19 Jan 2011 at 11:55am
would any one know were i could find a complete 2wd front end for a 6080? my spindle bushings are junk and the rest of the axle is extreamly loose!! or know of a way to put a narrow front end under it. I plan on pulling it alittle in farm stock class. thanks for any input.
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 1:36pm
Are the 6000 series and the later 170/175 axles the same or do they just look very similar?
Craig/insoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 2:50pm
6080 has heavy duty front end others have same front as 175. We put a 6080 front on 175 after tierod failure while hauling a 2000 lb round bale. I had to make a set of bushings because 175 had smaller diameter pivot pin.
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 3:46pm
Someone suggested to me to put a pedestal and nf off of a D19 on the front of my 6080.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis6080 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 4:24pm
so brianc,ont  they said to basically take the whole narrow front end off a d-19
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 4:54pm
I had posted earlier that I wanted to make our 6080 4wd into a narrow front puller. And they said to use the D19 front pedestal and fab it to the 6080 frame rails. Or if you could find a 100 series pedestal and nf might work also. I am going to put a D17 wide front under ours because they wont let a nf front pull in the 6500 lb and over class.
