WD-65 Project |
| Author | ||
Zyta
Topic: WD-65 ProjectPosted: 13 Jan 2011 at 4:05pm |
| Sponsored Links | ||
Zyta
Posted: 13 Jan 2011 at 4:06pm |
Zyta
Posted: 13 Jan 2011 at 4:07pm |
RSponenberg
Posted: 13 Jan 2011 at 4:12pm |
Ok,I'm getting this BUG too.... Guess its time to find a motor!!!!! Lol.
Zyta
Posted: 13 Jan 2011 at 4:25pm |
I am just glad I am in the assembly stage. Drove it around last summer and worked out all the little bugs/adjustments.
JPG AUSTRALIA
Posted: 13 Jan 2011 at 6:15pm |
looking good,willbe great when your done!
Reeseholler
Joined: 28 Mar 2010 Location: Port Matilda PA Points: 294 |
Posted: 13 Jan 2011 at 6:32pm |
Do you have any ways to do videos? I found that people really like update videos. Looks good.
Brian G. NY
Posted: 14 Jan 2011 at 9:45am |
Is that a WD tranny? Some say they can hold more torque than a WD-45 tranny?
acd21man
Posted: 14 Jan 2011 at 2:28pm |
looks like a 45 shifter but i can be changed so idk |
Denis in MI
Joined: 15 Sep 2009 Location: Norvell, MI Points: 832 |
Posted: 14 Jan 2011 at 3:08pm |
I think it is a bent WD shifter or a custom job, a 45 is tapered with a ball on the end
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25363 |
Posted: 14 Jan 2011 at 3:53pm |
In the other hand, replacement shifters for the -45 are not taperd, and do not have a ball end, just truncated like the one in pic, at least not the ones I got from Sandy Lake
I am still confident of this;
LouSWPA
Posted: 14 Jan 2011 at 3:55pm |
acd21man
Posted: 14 Jan 2011 at 6:08pm |
ya its curved more at the bottm more i c .............but iv seen a 57 wd 45 that had wd parts and a wd shifter
Steve M C/IL
Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Posted: 14 Jan 2011 at 6:34pm |
So the 57 had a WD tranny in it cause you can't mix em.
Steve M C/IL
Posted: 14 Jan 2011 at 6:39pm |
Lou that would be either a 230 or 262 gas engine.Likely a D19 engine(262).Either one needs the D19 governor if out of combine.
stick a 45D rear plate and flywheel/clutch assm on back and yer good to go. Edited by Steve M C/IL - 14 Jan 2011 at 6:42pm |
acd21man
Posted: 14 Jan 2011 at 11:44pm |
it come from AC like that they bought it new
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 15 Jan 2011 at 9:03am |
That shift lever doesn't look like ether a WD or A 45. It's too big in diameter. Maybe someone made it.
Dusty
LouSWPA
Posted: 15 Jan 2011 at 10:53am |
Zyta
Posted: 17 Jan 2011 at 9:53am |
In regards to the tranny shifter the tractor came with this larger diameter shifter lever and yes it is a 45 tranny. It wasn't made up looks to be original. I know another guy how has a WD-45 with this kind of lever and tower that came with his 45. This tractor did very little work ! have the history on it. Engine was distroyed because of a lack of antifreeze. The tractor never got repaired and sat up in a barn for years/years lift arms and drawbar have almost zero wear. I believe its the original shifter. The engine is a fresh rebuilt 262 combine engine with D-19 govenor on it. Linkage to control the govenor is from 45D. It sound really nice at 2500-2800 RPM. Allis Should have had this originally in a gasser. Looking for a nice 4 furrow semi mount plow for it.
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 17 Jan 2011 at 10:28am |
If it came with the 6 cyl. in it it must have been a Diesel to start with or a picker tractor.
Zyta
Posted: 17 Jan 2011 at 2:10pm |
no it originally had a 226 4cylinder in it with this shifter lever.
RSponenberg
Posted: 17 Jan 2011 at 4:15pm |
What motor are you using now,Zyta and what problems have you encountered???
Zyta
Posted: 17 Jan 2011 at 5:08pm |
This is a 262 combine engine. Removed the combine govenor and installed a D-19 govenor work excellent.
RSponenberg
Posted: 17 Jan 2011 at 6:23pm |
262 out of a combine is this the only choice,or is there others?? Was thinking on doing a diesel but not now,that I seen a gasser.Converting a gas to diesel would involve a little more work Imo.
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4573 |
Posted: 17 Jan 2011 at 8:24pm |
Is the manifold/carb still in the Skunk Works secret lab????
That JD air filter fits nice. We got that adaptor plate thing on the money. Edited by Calvin Schmidt - 17 Jan 2011 at 8:26pm |
