426 injection pump |
TrentH
Topic: 426 injection pumpPosted: 4 hours 19 minutes ago at 3:48pm |
I have a combine motor in my 8050 that I used the stanadyne pump when I put it in. It started leaking fuel on the backside of the pump out of a large plug by the bottom towards the rear . Does anyone know what size wrench for the plug? I’m trying to avoid pulling it off to tighten it.
Posted: 4 hours 14 minutes ago at 3:53pm |
1 1/8" I think.
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3630 |
Posted: 3 hours 23 minutes ago at 4:44pm |
We made a special wrench - bent with correct angle and the surface has to be ground FLAT - the nut is so thin the taper on a std wrench will not turn the nut but just jump off. For some reason the bottom plug and back nut that retains the advance spring will 'let go' on rare occasions. Many times the threads pull - maybe you will be lucky.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2481 |
Posted: 1 hour 33 minutes ago at 6:34pm |
Not related to your problem, but I noticed this on an 8070.[IMG][/IMG]20260302_151404_2026-03-19_18-41-32.jpg20260302_151409.jpg20260302_151404_2026-03-19_18-41-32.jpg
Edited by Lynn Marshall - 1 hour 24 minutes ago at 6:43pm |
