Allis 7040 powershift availability? |
| Author | ||
Mattman
Joined: 20 Dec 2012 Location: Plover, WI Points: 241 |
Topic: Allis 7040 powershift availability?Posted: 07 Jan 2026 at 7:37am |
Good morning Orangemen. I am doing some research in hopes to find a powershift clutch pack for my 7040 that I could swap into my pulling tractor in case of failure. My tractor is a 1976. Any assistance is appreciated.
| Sponsored Links | ||
Posted: 07 Jan 2026 at 7:55am |
There are 6 clutch packs in a Power Shift transmission and a torque limiter clutch on the flywheel. Which one do you want ????
Mattman
Posted: 07 Jan 2026 at 8:20am |
I am looking for the 6 pack assembly, not the limiter.
Posted: 07 Jan 2026 at 8:27am |
The whole PST transmission??? If the tranny you have is healthy and has the regulator pressure adjusted up a bit, 300 HP isn't an issue. Have you pulled this tractor yet ?? the torque limiter is the first thing that will slip, not the tranny. What gear(s) do you intend on pulling in ??
Posted: 07 Jan 2026 at 8:30am |
There's been a couple of good County Fair pulls posted on here that has a strong 8000 series FWA with PST and I'd guess you haven't seen the power he produces going down the track and winning the class. Probably 18,000 lbs or heavier. Posted in the tractor pull section by : Never Green "Son takes first at the fair again". Mr. Never Green has several pull videos of "farm" tractors that do quite well.
Edited by DrAllis - 07 Jan 2026 at 8:52am |
Mattman
Posted: 07 Jan 2026 at 9:58am |
Torque limiter has bolts to prevent slipping. I've pulled it 5 or 6 times successfully. I have not turned up the PS pressure yet. I did test all PS pressures and they were all around 200 psi.
Posted: 07 Jan 2026 at 10:08am |
Watch NeverGreens videos and quit worrying.
Mattman
Posted: 07 Jan 2026 at 10:15am |
I don't know if you have Facebook but here is a link of me pulling. Wasn't the greatest pull. I lost boost at 200 feet because I slowed down when I broke 6 mph limit. I was pulling at 10,500. I also need to shift more weight to the rear.
Edited by Mattman - 07 Jan 2026 at 10:17am |
Posted: 07 Jan 2026 at 10:34am |
Me no do Face book.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 716 |
Posted: 07 Jan 2026 at 12:24pm |
Not trying to be smart or anything but if it was me id try to find a complete transmission. That not that terrible a job. Ive done it 3 times. In my mind to change internals could get more dicey. Maybe you are a old hand at it and know more about it than i do
1984 80780
Mattman
Posted: 07 Jan 2026 at 1:13pm |
I agree. Healthy powershifts seem hard to come by though. I would consider myself a very capable mechanic/machinist that has never touched a powershift so anything could happen. I would like a replacement because I both work and farm and I know that it would take some serious time to go through one on the fly and get back to pulling.
Mattman
Posted: 07 Jan 2026 at 2:29pm |
Posted: 07 Jan 2026 at 3:19pm |
Should have been down one gear. A right hand throttle and a right hand power shift lever isn't the best scenario to have. Can you run 3,000 RPM?? If there isn't a rule against it, make it so. I assume you were in 5th gear ??
Mattman
Posted: 07 Jan 2026 at 4:32pm |
I was in 6th, should have been in 5th.
Posted: 07 Jan 2026 at 8:05pm |
Ground speeds on a 7040 PST and 18.4 x 38 rubber is 5.4 MPH in 5th and 6.8 MPH in 6th at 2300 RPM. 20.8 tires are faster yet. 6th was clearly too much gear in a 6.5 MPH class and your engine wasn't spooling up whatever turbo is on it because of low RPM. 5th gear at 3,000 RPM is 7.0 MPH with 18.4 rubber. A gear that you actually will stay spooled up and still manage to turn the tires faster.
Edited by DrAllis - 07 Jan 2026 at 8:06pm |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3662 |
Posted: 08 Jan 2026 at 7:43am |
Here’s the link that contains the YouTube video. https://allischalmers.com/forum/son-takes-first-at-fair-again_topic207611.html And I found this pull too. I think it’s the same tractor only different track & looks like driver downshifted near end of pull?Nevergreen if you read this post & watch video, please verify. https://m.youtube.com/watch?v=Nq_NX0g3eLk&pp=ygUJODA1MCBwdWxs Edited by AC7060IL - 08 Jan 2026 at 7:52am |
NEVER green
Posted: 08 Jan 2026 at 8:22am |
That is the same tractor with my kid driving, but it is a PD tractor. Have another 8050 with the power shift my brother drives, used to do very well until he started messing with weights so now my kid whoops up on him.
Edited by NEVER green - 08 Jan 2026 at 8:50am |
NEVER green
Posted: 08 Jan 2026 at 8:49am |
AC7060IL
Posted: 08 Jan 2026 at 9:04am |
NEVER green
Posted: 08 Jan 2026 at 9:14am |
Just turned up the pressure, it has over 11,000 hrs on it and it has never been pulled apart. Turned the standby pressure all the way down on the piston pump just so the brakes work, swear it stars easier that way. Not sure of the HP, 200cc of fuel and a ported ex manifold with a 3lm , we figure we better not push the hp any higher with the tractor being so heavy, sicky clay track.
Mattman
Posted: 08 Jan 2026 at 10:36am |
How much psi are you running to PS plates?
NEVER green
Posted: 08 Jan 2026 at 11:17am |
230 psi
