7060 muffler recommendations
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Topic: 7060 muffler recommendations
    Posted: 01 Dec 2025 at 11:14pm
Hey all,
I need a muffler for one of the 7060s.
I see shoup is running a sale right now, was curious if anyone has used one of theirs with success, or if its the same muffler as all states sells for 130bucks.
Thanks!
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2025 at 11:40pm
Back in the day ( 426 /7000 series) I would remove the muffler on a brand new tractor for modification while I was prepping it for delivery. I had an 1 3/8" pipe about 3 to 4 foot long that I would slide inside the muffler from each end. I would hammer the muffler up and down on the pipe like driving in fence posts. After enough hammering the spot welds on the baffles (2) inside would break loose and fall out each end, making a straight thru hole for the hot exhaust gases. It didn't really change the sound much at all but, (if I remember right) lowered my exhaust temps nearly 100 degrees F under full load. That didn't answer your question did it ????
Edited by DrAllis - 01 Dec 2025 at 11:41pm
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 11:35am
I'd be willing to bet they are the same,, more than likely, a stanley...
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 7:10pm
I put a muffler eliminator on my 8070. Hard to say it's any louder than before. That pipe through the hood spews above the cab top so maybe so? Straight pipe it....my open station 220 is another story. It's got a factory 7030 muffler.
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 2:24am
Straight pipe is not loud if done right,keep it the same diameter as turbo outlet,3.5 inch or so ,5inch or bigger will drone. Keep the lenght as least as long as the muffler,no short stack. Ihave mine about as high as indicators on cab.
Edited by JPG AUSTRALIA - 03 Dec 2025 at 2:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 3:57pm
Go to a muffler shop and get a length of straight pipe long enough so that it meets the top of the cab.  Have it on my 6080, not overly loud.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2025 at 7:44pm
If you put a muffler on it I’d only use a very reputable brand. Been down this route with a cheap muffler, gained 20 hp removing the cheap muffler.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2025 at 11:31pm
Had a neighbor who would always say that if you straight pipe anything (even the 10hp lawn mower) you’d gain 5 hp..
I’d straight pipe it, love that sound of a 426 purring in the fields!!!
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2025 at 6:15am
I use Shoup for many of my farm parts and highly recommend them. Great customer service and fast shipment.
Part time farming with a 1980 7060 and 1984 F3 hydro.
This page was generated in 0.172 seconds.
