Plugs
Brinky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinky Quote  Post ReplyReply Direct Link To This Post Topic: Plugs
    Posted: 16 Aug 2025 at 8:49am
After having my starter and magneto rebuilt, the Allis b finally is starting much better but occasionally she doesn’t want to play. I have NGK BP2HS plugs that were fitted before I got her. Is there a better plug ? I have read of others that aren’t available in the uk
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 9:27am
NGK have good plugs.  I use them in several of my tractors.  Before switching the plugs, I would be looking at the rest of the ignition system.
Also make sure there are no obstructions in your fuel system.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 9:31am
Just watched a Y-Tube video about "Fake/Counterfeit" NGK plugs on Amazon. Might be true/might not. Buyer beware. I just got some from Rock Auto for my truck. They appear to be the real thing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 9:46am
NGK 3210 or B4..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 9:46am
I have recently cleaned out the fuel system, I only have a battery , starter and magneto
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 12:30pm
The best plug I've found for my WC, which would work just fine in your B, is NGK Iridium
part # XR4IX, Stock # 7189 from Rock Auto. They have the best price and they are not cheap knock offs or imitations like you may see on eBay. BUT, before you continue with things mentioned above, do a real good valve adjustment. These engines are solid lifter engines and need occasional valve adjustment. Chances are those valves haven't been adjusted in many many years. Out of adjustment valves can cause starting issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 12:49pm
I also agree NGK are great plugs. However BP2HS would not be a correct plug to use. This plug is a hot plug with a projected insulator type. this would lead me to believe that it was fouling plus or maybe that's just what the person had lying around.
 The Factory plug would be an AC45, which is a NON RESISTOR plug that you need to work properly with a magneto. The correct cross to a NGK is a B4 stock #3210
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brinky Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2025 at 1:58pm
Thanks for all the info
This page was generated in 0.176 seconds.
