Ran When Parked... |
Page 12> |
Author | ||
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1180 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Jan 2025 at 8:46am |
I bought this engine (cheap) mounted on an old Allis-Chalmers hay blower. Cylinders #1 & #4 have large chunks broken out of the sleeves, I presume caused by water freezing. I'm hoping I can get the sleeves out without damaging the block.
Sponsored Links | ||
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 33580 |
Pretty Ugly
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24533 |
scuff and buff, she'll fire right up !!!! ATF/ace 50:50 and some patience. OK, maybe a lot of patience. nice 'winter project' though...
Yup. I cannot recall ever seeing worse
Might take several winters!
at 71 I'm not in a hurry....though it'd be nice if ONE of my 2 big toes healed up soon...
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 706 |
If it were me, I scrape an vacuum all the loose chunks out and if I could get a fluid to sit in the cylinders, I's use an actual rust remover- Evap-O-Rust, not some mix of anything. Then, when as much rust is gone as possible, load it up with some sort of penetrating oil and you may be able to get it disassembled without too much stress on the block.
I used this method on a "B" engine with 2 rusty cylinders and it runs great years later with the pistons never having been taken out. I get your engine isn't going to do that, but getting rid of the rust will help it come apart.
1951 B
captaindana ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2546 |
Good luck Les. The G I had once upon a time ran when parked also. Looked just like yours! š«
Blue Skies and Tail Winds
Dana |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8297 |
Wow- junk it and get a different one!
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3506 |
Might be a great candidate for an electrolysis soak (e-bath). Anyone on here ever do an entire engine into a e-bath? How are its head, valves, intake, exhaust manifolds ??
Les Kerf, is your engine a D14 149cu in from an AC 30L long conveyor or 30S short auger blower?
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86903 |
I thought it might be a 125 CE engine... but your right, possible a 149..
dr p ![]() Orange Level ![]() Joined: 24 Feb 2019 Location: new york Points: 1363 |
Les, is that the blower that sold in tioga county pa in Sept?
Pretty rough, not sure what will be salvageable.
I am not knowledgeable enough about blowers to say but it doesn't have an auger. The engine is a 125 for certain, hand crank only. I will try to get some more photos
No, this one has been sitting on my neighbors farm here in northern Idaho for many years
I actually have different one that looks like it will be much better, although it too is stuck. We got it to move about a half turn today
son got a CASE 530 backhoe that was setting in the corn field for 10 years with not stack on it.. ( 15 years ago)... I rebuilt the motor for him... Looked very similar to that one.. Once you get the pistons and crank out and pound out the sleeves.. you got the bare block... If not crack, it will clean up OK.... NEW KIT fixes about 90% of those problems ! ... I had to get the crank turned .020 to clean it up due to rain water in the crank case..
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 898 |
My 60a combine engine looks just like thatā¦
In the process of getting the sleeves out to inspect the block. |
plummerscarin ![]() Orange Level Access ![]() Joined: 22 Jun 2015 Location: ia Points: 3864 |
Looks like the one in my WD project with 2 less cylinders. After complete disassembly the block cleaned up nice and the crank was turned .010ā under. New engine kit is making it look real good so far.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7474 |
My 59 D14 looked similar to that when I got it. Soaked it for several months and pounded out sleeves and all. Both the crank and cam were still good. Put a major OH kit in it and rebuilt the head. She runs 100% now.
Bottom View ![]() |
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4790 |
brass, copper, and aluminum are negatively affected by electrolysis, it's also a line of sight operation, anode needs to be able to "see" all nooks and cranny's to clean them, would be hard on an assembled engine
Allis Express North Georgia
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3905 |
I like a challenge, but I might give that one a pass!!
Here is my Model 60 Combine engine, just got it freed up yesterday. MUCH better looking on top, have yet to pull the pan. ![]() |
My bottom end looks pretty nice other than the crank seems to be a bit scored. Hoping it will be fine for the combine being I will have more into the engine than itās worth.
![]() Edited by 55allis - 08 Jan 2025 at 2:38pm |
Les Kerf, just wondering how your 125 engine is coming along? Thanks for all your follow up photos & answers.
KenBWisc ![]() Orange Level ![]() Joined: 15 Sep 2009 Location: Fall Creek, WI Points: 1184 |
I fear that is more than electrolysis can handle from my experience.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3856 |
just make sure the valves seal and replace the oil sump pickup pipe that is probley cracked and it will run
I am setting the blower engine aside for now and focusing on the Model 60 combine engine as it is in MUCH better condition. Combine bottom view: ![]() Everything looks so good I am not even going to remove the bearing caps. Combine head: A basic cleanup and valve job should suffice. ![]() Combine Head #3 Cylinder: The intake valve seat has been re-worked and machined into the head somewhat deeper, maybe 1/16" or so. Not easy to see in the photo. I am not going to stress over it. ![]() I am planning to re-seal everything and set it aside. I have a derelict Model C in which I hope to install this. That will warrant a new topic. |
Page 12> |
