Opinions on air jacks
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Topic: Opinions on air jacks
    Posted: 14 Feb 2025 at 6:20am
I have been thinking about buying an airbag jack (maybe this one or similar):
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2025 at 6:40am
Buddy has one and luvs it! I got a 5 ton - just got it , havent used it yet- heavy sucker!
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 10:09am
Not had experience of them, but have seen a few guys on the youtubes using them (and not the kinda fellas to do a shill promo vidya either) and heard nothing but good things. Same goes for Vevor kit in general actually.
For the amount of jacking off https://www.youtube.com/watch?v=d4zI4JpMfks I do, I'll stick with my old hydraulic ones until they're wasted. May consider one when the time comes though.
KRAKMT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KRAKMT Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 10:26am
I use one to turn my atv sideways in my toy hauler. I set it on a lazysusan I made to turn.
Works well but any perpendicular movement is hard on them. Inside is a series of cups that slide together when releasing the air and going down.
I imagine they are not very robust.
I need to modify some bracing.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2025 at 11:33am
My thoughts would be how much lateral movement can it tolerate? One could bump on the side of that bag with something sharp, and it’s game over.
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2025 at 8:11pm
Thanks a lot. I clicked on it and now I get that add 2 or 3 times a day no matter where I browse. Can't hide.
I used to be young and stupid, now I am not young anymore.
Dirt Farmer View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dirt Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2025 at 2:06am
That could start a whole another topic, why are there so many ads everywhere you look anymore. Can't read a single news article without interruption midway through. Sorry, just had to vent. Thanks AI...not
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2025 at 6:18am
Yeah, same here
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2025 at 8:03am
I use brave browswer. I have it set to delete cookies when i turn it off. Very few ads except on rumble
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2025 at 10:17am
When saying air jack - way back use to have one in shop I worked in back in high school .
Was a 8" or so round cylinder with arms attached and a rolling platform under it . Hooked onto shop air and it was like a air powered bumper jack . It had a safety pawl that locked into base as cylinder raised .
 Seems a lot safer than a airbag type unit for general use .
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2025 at 5:16am
Been reflecting on these. Somewhat handy and not. No mechanism to keep from tipping or kicking out. Guys I deal with in wrecker and recovery like them as short yet inflate long, have seen kick outs but use in teams not singularly, always use cribbing or blocking stands around them. Only as dangerous as allow them to be, as with any lifting mechanisms can be.
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2025 at 6:27am
They can't be as dangerous as the 'handyman' jacks. I have one that was my dad's. I am very careful whenever I use that thing, but there are a lot of things they are very handy (but dangerous) for.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2025 at 7:53am
i could see it if you were on FLAT CONCRETE and then blocked under the car frame after you raise it up.. Maybe not go to FULL EXTENSION ?
I do a lot of work outside / gravel / field / not level.... dont seem like a good idea there.
