WC Final Drive Oil
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Topic: WC Final Drive Oil
    Posted: 30 Jan 2025 at 2:43pm
Would EP "00' grease be close to the specified 250 weight oil called for in the book for the final drive oil on a WC?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 3:33pm
Can't tell you. If it was mine the axle/wheel hub bearings would get packed with wheel bearing grease and I'd throw in several tubes of "corn head grease" in the gear case.  Probably 6 tubes to a side if I was guessing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 3:57pm
00 grease has the consistance of apple sauce... That ( or 0 NLGI)  would be comparable to the corn head grease that Dr mentioned..
Edited by steve(ill) - 30 Jan 2025 at 4:03pm
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 10:13pm
Would 85W140 work?
That’s what I put in my wd and Wd45 final drive…
Never change a WC’s though.
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 10:48pm
i use alot of 00 grease on things here , a lot on the lawn and garden gear boxes it will get were it needs to be in there and stay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:24am
That's the deal with an RC -WC or WF. All they have for a seal around the wheel hub is a large diameter cork gasket that is prone to seepage when oil is used, which is what they used back in the day.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 6:31am
that’s why I have corn head in my WC, its best property is the fact that it goes back to a semi-thick state as it cools and this stops a lot of the seeping that comes when they sit.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 7:47am
Yep we packed all of the bearings with grease already. I was not sure if corn head grease would lube that top bearing enough, that is  the route we will go.  thanks for the info! This has been a 4 year long nut and bolt resto so we wanted to get it right.
KY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2025 at 7:49am
85-140 is too thin for a WC . There is a big cork "seal" that is very prone to leaking
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 10:10pm
It's been a while but I thought a new rubber seal was at one time available from AGCO. I was going to restore a WC many years ago and I investigated things like that when I worked at a dealership. Been 30 years ago though.
Wink
I am a Russian Bot
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2025 at 12:57am
I don't remember a lot about our WC.  But I sure do remember Dad having a good supply of SAE 140 around to keep her lubed up.
Phil48ACWC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil48ACWC Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 6:27am
In my '48 WC I replaced the large cork seals with the new rubber ones. I greased the rubber seals with heavy grease and added preload to the seal by adding a shim ring made from a plastic 5 gallon bucket. I use 85W-140 gear lube with almost no leakage. Working great now for 3 or 4 years. All the brake box seals were replaced along with brake linings about 5 years ago. A WC with brakes that work, rare and amazing!
ekjdm14 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ekjdm14 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2025 at 7:27am
Wonder how many members read Morse fluently LOLWink
