Diesel or gas |
Author | ||
D171958 ![]() Bronze Level ![]() ![]() Joined: 03 Aug 2024 Location: Iowa Points: 68 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2025 at 8:40am |
Wondering if it would be better to put a 226 gas engine in a d17 or a 262 diesel.
Sponsored Links | ||
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21745 |
What chassis do you have now ?? If it is a GAS chassis, you must stay with a G-226 gas engine. If it is a DIESEL chassis you must stay with the D-262 diesel or G-262 gas engine family. The clutch shafts between the 226 and 262 families are different lengths. The side frames length are also 3 inches different and the hoods, etc.
Edited by DrAllis - 21 Jan 2025 at 8:57am |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24584 |
OK, just HOW do you guys keep all this information in your heads ????
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8410 |
Mad genius's. Navel maneuvering
So to engine swap it it will be a big deal.
RedHeeler79 ![]() Bronze Level ![]() Joined: 09 Sep 2023 Location: NE Kansas Points: 197 |
Yep, lots of differences between the two. Even the lower steering shaft, and the fuel tank, radiator, throttle linkages, etc, etc…. Additionally, the 262 diesel has quite a few inherent problems that are costly and time consuming to fix, and parts availability is a real problem for them also.
Edited by RedHeeler79 - 21 Jan 2025 at 5:45pm |
D171958, you have us all wondering if you even have an engine at all ??
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1221 |
I too marvel at this! ![]() |
No I don’t have an engine for it seen it on Facebook it’s a gas series one I thought it would be pretty cool to put a Diesel engine in it if it was easy and cheap Thanks.
Easy? Nope. Cheap ? Not a chance !!
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
I saw a guy put the diesel side rails hood etc on a 226 gasser for tractor pulling.
In Nebraska, not sure how much of an an advantage it would be ??? Thought it was interesting. |
Moves the front wheels out 2 3/4" inches making the nose a little heavier.
Always wanted to make my old D17 series I diesel into a 6 cyl 262 gas puller.
Most places would not care but thier's a few antique rules book pulls that would not allow.... So I just made my 4 cyl gas big cube.... I guess there's gotta be some rules... Edited by Macon Rounds - 22 Jan 2025 at 2:41pm |
