8030 Steering Cylinder
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Steering Cylinder
    Posted: 18 Jan 2025 at 8:34am
I am getting the power steering cylinder by my local shop - the piston has several scratches in it.  Also need to put new balls and sockets in it.
Looking at the parts book, items 19 an 21 both have the same part number (70276006) although they look different.  Probably a typo, but can someone give the correct part numbers and how many are needed?
Many thanks!
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 8:38am
70272615 is the correct # for 19
Unfortunately no dealer has in stock - it is NLA - no aftermarket. It is a spacer.
Edited by tbran - 18 Jan 2025 at 8:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 8:58am
Thanks tbran, do you have any dimensions of the spacer?  Maybe I can get my fab shop to make a few up.
Edited by DSeries4 - 18 Jan 2025 at 9:10am
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2025 at 9:16am
Series4 that # 19 ID is the same as # 18 bushing, OD is 1>620", thinkness is 0.170" may be wore a wee bit, that shim-washer is tapered on one side maybe for ese of installation
