D-15 start push button |
Page 12> |
edmo
Joined: 13 May 2011 Location: So. Missouri Points: 94 |
Topic: D-15 start push buttonPosted: 03 Jan 2025 at 5:43pm |
Trying to put a few things back in place with my 1964 D-15, II series. think someone by passed the push button starter switch when replacing the key switch. can i test the button switch with simple continuity test or does it have to meet an amp rating?
Joined: 11 Sep 2009 Location: illinois Points: 90846 |
Posted: 03 Jan 2025 at 6:33pm |
the push button should pull in a RELAY that energizes the starter.. So the relay is a LOW AMP button... I have been using a push button from AUTO ZONE... I think it is rated at (50 ?) amps... you probably pull about 10 amps ... Right now the KEY is doing that in the START position ??
YES, you can check continuity, and that NORMALLY works... MIght be a good time to buy new.. Edited by steve(ill) - 03 Jan 2025 at 6:40pm |
Posted: 03 Jan 2025 at 6:36pm |
looks like most of the button available now are 50 amp... that is GOBS BIG...
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 03 Jan 2025 at 7:30pm |
Ed Does your Ser.II D-15 have a Push Button for the Starter today. If it does it is not factory original. The function of the switch you describe with the Starter Solenoid activated by turning the switch to the start position is how a D-15 came from the Factory. No Push Button. The Factory Solenoid is mounted on the L/H side of the Starter. G |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5476 |
Posted: 03 Jan 2025 at 7:42pm |
Dad bought our series II D15 new in 1968, it has always had a push button to start. Turn the key to the start position, push the starter button to start.
Posted: 03 Jan 2025 at 8:11pm |
Seems like the D15 series I had a key... then the series II had a ignition key with a START BUTTON... WHY ??? Dont know... D17 always had a key ignition / start.. ??
Just checked my IT- AC201 manual ... yep, thats what it shows Edited by steve(ill) - 03 Jan 2025 at 8:17pm |
AC720Man
Posted: 03 Jan 2025 at 8:27pm |
My D17 diesel is key start. Go figure? Not sure why they changed unless they started having key start issues with it not holding up? That would be my guess.
lentsch
Joined: 10 Feb 2011 Location: Glencoe,Mn. Points: 236 |
Posted: 03 Jan 2025 at 8:52pm |
WD,D15,190XT,7000,8010x2,7060,8070
edmo
Posted: 03 Jan 2025 at 9:49pm |
I was a teen in 64-65 and didn't get much time on the new AC. I was usually stuck with the old Farmall H. I do remember though as it having the black start button. When dad died and I brought the tractor here, it had the start button, but the tractor started with the key. I assumed that the key ignition had been replaced at some time and the start button was just disconnected or had quit working. It still starts with the key, but its a dinky little key, hard to get a grip on and is loose and sloppy in the key slot. I thought while i was replacing the key switch i would reactivate the push button. the one I took out looks like it would be original, rubber cover on button, switch body slightly smaller than an old match box carried around before book matches, with two spade terminals on top side(one bigger than other).
The schematic I have for the gas model shows the push button. Was just trying to get rid of the dinky loose key problem and make it like original. I assume if the button was original, the keyed ignition would not have a start position, but??
Posted: 03 Jan 2025 at 10:11pm |
yes, your correct... something like this... you should have POWER to one wire, and the OUTLET wire feeds the ignition coil and the start Button.
![]() Edited by steve(ill) - 03 Jan 2025 at 10:15pm |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 04 Jan 2025 at 8:58am |
Gary, Series 1 D15s did not use a push button start. It used the same Delco Remy switch used on the D14s. Early series 2s continued to use the same Delco Remy switch PLUS the addition of a push button starter switch. Later Series 2s went to an Indak key switch with a push button starter switch.
DSeries4
Posted: 04 Jan 2025 at 9:07am |
Original D15s: Series 1 gas... 63, 64 Series 2 (I restored my neighbor's 1 owner all original 64) ![]() My 66 D15 Series 2 ... |
DSeries4
Posted: 04 Jan 2025 at 9:11am |
A continuity test can determine if the switch works. It is just an on/off device. New switches are available and pretty cheap, I would just change it out if I had any doubts about it.
Steve in NJ
Posted: 04 Jan 2025 at 12:25pm |
I remember when I first started getting into the "D" series Tractors building the wiring systems, some of the same models had a key, some had a button. Didn't matter what series. Now, some could've been changed over as the years progressed. After a while it started driving me crazy, so I always asked the customer which starting system their Tractor had. The wiring along with the key switch is a little different from one another. And that Garden Tractor key switch AC was usin' for a while wasn't nothin' ta' write home to Mom about either!... ![]() Steve@B&B
Gary
Posted: 04 Jan 2025 at 2:54pm |
Myron My 1966 D-15 Ser.II has a key only start. No sign of ever having a Push Button. Couldn't find any reference to a Push Button in March 1966 Parts Catalog. My 1965 D-12 Ser.II on the other hand does have the Push Button. Gary |
Posted: 04 Jan 2025 at 5:03pm |
the BUTTON is shown on the D15 II electrical drawing in the IT book .... which i assume they took from the Service Manual.
DSeries4
Posted: 04 Jan 2025 at 7:07pm |
Gary, the original operator's manual that came with my 66 D15 shows a "starting switch" on a picture of the dash as well as a "starter switch" in the wiring diagram. It is part number 70253322 in the AGCO parts book website. ![]() ![]() |
Pat the Plumber CIL
Joined: 11 Sep 2009 Location: Springfield,Il Points: 4988 |
Posted: 04 Jan 2025 at 7:24pm |
My 65 Series II D15 has the push button, same as my 65 Series IV D17. My Series I D17nf has key switch
Leadoff
Posted: 04 Jan 2025 at 8:45pm |
Switch vs Push Button Debaters
I am betting the Allis Chalmers Legal Department influenced the decision to move towards the Push Button design for starting the engine. It forces the operator to really want to start the tractor, and think before hitting the button. Is it in gear? Have you engaged the clutch? etc Brakes? PTO Many industrial equipment in Plants have a similar setup switch on/off momentary push button for basic safety to start operations. AC Industrial Division might have had some input - who knows The redesign of the top of the Power Director/Hand Clutch with the Guard to minimize accidental depression of the release button comes to mind (apparently after an unfortunate accident) My 1965 D15 II, 1965 D17 IV, and 185 have the push button. My 1963 D17D III (purchased used from local AC Dealer) had the old style S1 switch to start, with the push button wired to engage the manifold heater!! I rewired it to be the same as the 185, switch off-on-heater, push button start |
1963 D17D Series III. 1965 D15 Series II. 1965 D17 Series IV. 1975 185. 1978 716H. 1979 716H. 1965 780 Harvester/1R&DC. 1957 Model 73 SC 4 Furrow Plow
Gary
Posted: 04 Jan 2025 at 10:24pm |
Myron I looked in the Numerical Index in the back of the March 1966 edition of the D-15 Parts Catalog. There is no P/N 253322. P/N jump from 246724 to 277644. That is strange. Gary |
Kenny L.
Posted: 05 Jan 2025 at 6:42am |
Gary, look up p/n 239346 it replace p/n 229855 use prior to sn# 9001. In my master numerical index book ( June of 1969) p/n 229855 to use p/n 239346- cap assy 2cp, h3,hd3,d14,d15,d17,170,180,190 p/n 253322 switch assy H3,HD3,D15. D17,170,180,190 HTH.
Gary
Posted: 05 Jan 2025 at 9:51am |
Thanks Kenny 239346 Cap Assy, took me to page 164, a schematic of the Dash, similar to Myron's picture of a nicely restored Ser.II. Looks like a rain Cap. There is only one Type of Key Switch shown, Ignition and Starting There were 2 Suppliers: Delco Remy and Indak. Surprising the schematic doesn't show the Choke in the middle of Trim Panel. Also lists 2 Trim Panels, 2nd effective 9001. On page 275 a schematic for an optional horn shows a switch 228329, but doesn't identify where it is located. Gary |
Posted: 05 Jan 2025 at 12:37pm |
why do you keep beating a dead horse ??? The ELECTRICAL DRAWING of the D15 II shows a PUSH BUTTON START switch...That is how it came from the factory.... the OPeratoros Manual shows a picture of the switch on the dash..
Edited by steve(ill) - 05 Jan 2025 at 12:38pm |
Gary
Posted: 05 Jan 2025 at 2:19pm |
L'il Stevie I have more experience with Allis Chalmers Tractors than you could possibly acquire, even if you live to be 100. I have mentioned it before, and I'll mention it again, my father started his Allis Dealership in 1953 when the WD-45 came out. I was 7 at the time. I spent many moons behind the Parts Counter in my teenage days and using Parts Catalogs to provide Service to Allis Customers. So don't try to tell me what you might have found in some IT Service Manual and think it is the almighty Facts. IT Service Manuals are just a guide, and have a reputation of not being very accurate The same is true for the Allis Service Manual, a guide for it's Trained Mechanics when working on Allis Equipment. The same holds true for the Allis Manuals for NEW Allis Equipment Owners. A search on Ebay found no less than 5 different ALLIS ORIGINAL 'Operators Instructions for Model D-15 Tractors'. The early D-15's ( which were never identified by Allis as Ser,I) There are 2 Operators Manuals: Form TM 271A and Form TM 274. For the D-15 Ser.II which started in 1963 at Serial 13001; There are 3 Operators Manuals: Form TM 341A, 341B, and 341C. Who knows what the changes might have been, I have never seen changes identified. It needs to be noted that all Technical Manuals for New Models get printed way ahead of the actual beginning of Tractor Model Production. Manuals are needed for advance Technical Training etc. The only Factual Place to find accuracy in all the Parts and Part Numbers that make up Allis Equipment is in an ORIGINAL ALLIS PARTS CATALOG. And as I quoted, that is where I get my information, the True FACTS. So l'il Stevie, you can take your Smart Ass Comments, the ones you are so famous for over in the Forum that is titled 'Politics' , and you can shove them where the Sun don't shine. They don't belong anywhere on the Allis Chalmers Forum, and especially not anywhere except the so-called POLITICS section. Gary |
Posted: 05 Jan 2025 at 5:42pm |
I couold not care less where you grew up or what you THINK you know about Allis... The FACTS are you can NOT ADMITT that you are ever WRONG.. Everyone makes some mistakes from time to time... Your only goal in life is to TRY to point out when i miss spell a word or phrase something you dont like..... Give it up SOY BOY.
The FACTS are that aa dozen people have said they have a Series II with a push button... Photos from the service manual SHOW the button.. Prints from the manual ( and IT ) SHOW the button in the drawing.. ITs OBVIOUS.. IT HAD A PUSH BUTTON.. SO WHAT.. WHY ARGUE ? .... Just say "OK, MY MISTAKE... some came with a button "... But you INSIST that YOU CASNT BE WRONG.. ----------- and IN THE ORIGINAL POST i NEVER SAID the button was ORIGINAL... The OP said he had a tractor with a button and wanted to know how to wire it up... SO WHAT... I really dont care WHAT YOU THINK...The question was how to wire a BUTTON..
Edited by steve(ill) - 05 Jan 2025 at 5:44pm |
Posted: 05 Jan 2025 at 5:45pm |
and i said the BUTTON would pull "about 10 amps".... are you SURE you dont want to argue that it is really 9.7 .... or maybe 11.2 ???
--------------------- So l'il Stevie, you can take your Smart Ass Comments, the ones you are so famous for over in the Forum that is titled 'Politics' , They don't belong anywhere on the Allis Chalmers Forum, a So the TRUTH come out.. SOY BOY DONT LIKE MY CONSERVATVE POLITICS... Take your OWN ADVICE and STOP DISAGREEING on MEANING LESS POSTS in OTHER than the Political Section !!! Edited by steve(ill) - 05 Jan 2025 at 5:57pm |
Gary
Posted: 05 Jan 2025 at 9:07pm |
Can't admit I am wrong? I'm not wrong about anything. I'm just the messenger, posting facts that I read in the Allis Bible, an original D-15 Parts Catalogue. Yes there were over 2,000 D-15's that left the Factory with that rubber capped Push Button. But they were all Diesel's, Push Button connected to the Preheater. G |
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55293 |
Posted: 05 Jan 2025 at 9:15pm |
What goes on downstairs should stay downstairs. It's why this forum works so well. I guess that certain experts at one thing shouldn't think that that expertise translates to all things...
Posted: 05 Jan 2025 at 10:48pm |
Yes there were over 2,000 D-15's that left the Factory with that rubber capped Push Button. But they were all Diesel's ![]() Edited by steve(ill) - 05 Jan 2025 at 10:50pm |
DSeries4
Posted: 06 Jan 2025 at 2:08pm |
Look at the wiring diagram people! A white wire goes from the push button switch to the solenoid mounted on the starter! Nowhere do you see a solenoid for the manifold heater that is found on the 2000 diesel models - the operator's manual for the D15 diesel does show that. If you want to question original Allis drawings, feel free. I follow them. Why do the majority of D15s I see at shows have a push button for the starter? Is it a conspiracy? I don't think so.
Page 12> |
