Allis D10 questions
missouri wc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote missouri wc Quote  Post ReplyReply Direct Link To This Post Topic: Allis D10 questions
    Posted: 09 Nov 2024 at 1:30pm
I recently bought a lot of allis tractors and parts. (mostly wd/wd45). There was a d10 that was included but it is rough shape. The serial number shows it to be a 1961. I do not know anything about the d10s. It does not have a pto and no hydralics. Did any come this way? it also has yellow paint on it so i could be an industrial. Is it worth more to leave as is? How hard would it be to located all the hydraulics and lift and pto for this tractor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 1:36pm
there were a couple different VARIATIONS of the D10 along the "industrial" line.. Does the Decals say D10 ?  Or are you saying it LOOKS like a D10... Industrial would be yellow. Could have different front axle or  radiator cove or others.. Does it have spin out rear rims or standard rims... No pto or hydraulics might be a clue.. No good reason to REMOVE them.. probably never had them....... PHOTOS ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 1:39pm
here is a photo from HUTCH in 2007.........
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2024 at 1:41pm
here is another "version" .... called the I40
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 9:21am
Where is the Gear Box Steering Arm on the I40?
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 9:39am
power steering...
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2024 at 9:47am
1961 D-10 prior to Ser. 3501 would be 138 cu.in., 6 volt electrics.
1961 D-10 Ser. 3501 and up would be 149 cu.in. 12 volt electrics.
The I40 pictured is 1964 or later Ser. III
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote missouri wc Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2024 at 7:51am
I will get pictures this week when i get back to the farm. It does have d10 decals and d10 grille. No spin out rims.
This page was generated in 0.073 seconds.
