oil seal(s) part number,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: oil seal(s) part number,,,,,
    Posted: 30 Oct 2024 at 8:37pm
 I have come up on a puzzler on some old oil seals with unlegible numbers and the local Napa and Oreillys are claiming no knowledgable way to do a search with the seal size as  I was very carerful removing the seal so as to not oblterate any numbers that may still be  left,,,,, The first three number are 156_ _ Other numbers on seal are  R28  and  C/R     and USA   .
 I have done several  google searches using different wording on "search by size" and I get nowhere,,,,?? I have a good Starrett Dial caliper if someone knows of a site that allows you to enter the id, od, and the width to find the correct seal.
 Any takers on this one,,,,?? Many Thanks,,,,Clap        -
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 9:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 9:41pm
go to the left of this page and look up the OD - ID........
https://www.rainbowprecisionproducts.com/index.php/oil-grease-seals-bronze-bushings-national-oil-grease-seals-c-292_539#1
Realize that MOST seals are really METRIC size... common lawn mower shaft is .669 inch  bore seal.... that is REALLY 17 mm.
Edited by steve(ill) - 30 Oct 2024 at 9:45pm
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 6:08am
Hi Joe
C/R stands for Chicago/Rawhide, a previous manufacture now owned by SKF.
Here is a link to 'Standard and Metric Oil Seal Size Chart' that will keep you busy.
https://www.globaloring.com/oil-seal-size-chart/
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 6:11am
Try a business that specializes in industrial bearings and drives. They can usually identify what I need from just the measurements. I get most of my bearings and seals from a local company. I hope NAPA is not getting like the other parts stores and hiring people who only know a computer and nothing about parts.
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 7:19am
Was in to Napa just yesterday needing a pair of 1157 lamps. Counter guy had never heard of them and had to ask owner who laughed. NO and wouldn't have believed it if not seen it myself.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 7:46am
  Hey Hubert,,,,I'm afraid we are already there as I had to ask the counter guy at Napa,, TWICE to at least LOOK and see if he could possibly find it  on his computer.
 Just a few short years ago, there was an older Gentleman that had an Auto parts store that did NOT have a computor ,,,just about 10 books ,,each about 2" thick  and if there was a part ever made it would be in one of those books and it might take ole Ken longer than a pair of minutes,,,,BUT FIND IT HE WOULD,,,,!!! To him,it was a matter of taking care of his customers .
 I kept trading with Ken as I knew it was just a matter of time before the Oreillys and Napas would take him under and he finally closed the doors a couple of years ago and NOW listen to all those that went with the big stores lamenting that they didn't try to keep Ken in business,,,!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 11:17am
That’s one of the reasons I support the independent, mom and pop businesses whenever I can. I may pay more but the top notch customer service and keeping the money in the community is worth it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 1:42pm
Finding a good parts person in any type store today is hard, when you do stick with them. There aren't any places local to me anymore that have anything close to a competent parts person, although I do have many contacts all over the country that are willing to go that extra step to serve a customer. I have a room full of old paper catalogs that were being thrown out when everyplace was switching to computer and thought they would never need them any more.
What is the shaft size, bore size, allowable thickness and product you are wishing to seal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 8:58pm
  Hey PaulB,,many THanks for the your help,,,!!ClapClap
  The transmission output shaft size = 1.550
   The Transmission Bore size=====  2.435
   Thickness of seal body======== .500
 Product is 85-90 gear oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 9:48pm
I got a catalog from a bearing supplier when I was Millwright and it listed bearings and seals in it - covered about everything made .
 Seals were listed by class from 1 to 6 depending on the lip design and intended purpose.
Shaft size , bore size , depth of bore , material it's holding in or keeping out.
So from single lip , dual lip , and or speed of shaft all go into seal type .
 I could look up a seal I thought would work to replace present application and call supplier to see if they had that seal or comparable replacement .
 When a shaft is worn with groove in seal surface , you can get a speedy sleeve and matching seal to make new surface rather than replacing shaft / did that on my HD4 axle shaft outboard seal .
Measure the required dimensions to the nearest 0.001" or 0.05mm. ❏ Shaft Diameter. ❏ Bore Diameter. ❏ Width. 3. Select the appropriate seal material.
712 pages
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 9:51pm
Here is GARLOCK size listing page
1.500 2.437 0.375 63 0649 , 1.500 2.437 0.375 66 0649. 1.500 2.437 0.437 63 0650 ,
... BOREWIDTH. PART NO. SHAFTBOREWIDTH. PART NO. S-1 ... 2.435. 4.094. 0.625. EQ. 4896. 2.436. 3.436. 0.625. EQ ... 1550. 2.625. 3.250. 0.375. 61. 1550. 2.625.
267 pages
Missing: 1.550 ‎| Show results with: 1.550
Edited by Coke-in-MN - 31 Oct 2024 at 9:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 9:57pm
well the numbers dont exactly line up... but a CR156xx  ... closest one is 15620  ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Oct 2024 at 10:07pm
Category Files
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2024 at 8:16pm
 Hey Steve,,I do believe the 15620 is the one I'm hunting. I went down ther but the one guy that WILL do a deep search was not on shift till tomorrow morning and I;ll be thereN bright and early. Now that I look at the almost faded number on seal,,it sure looks like 15620 seal.. Many Thanks to you and Coke,,,!!!!ClapClap
