185 3pt lift capacity? |
Wes(Va)
Bronze Level Joined: 08 Apr 2024 Location: Elkton, Va Points: 5 |
Posted: 24 Oct 2024 at 10:04am |
Hey guys, this is something I've not really considered before, but am looking at a 3pt tedder and want to use the 185. Was told the tedder weighs 2000lbs. I think it'll be fine, have fluid in front tires, no cast up front. Looked at the dealer literature from when the tractor was bought new, and it doesnt say.. thanks, Wes
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 900 |
I believe the tractor will pickup more on 3 pt. than that. A lot depends on how far back from lower lift arm pins it's weight is. You may be looking for front weights if it sits back to far.
Orange Level Access Joined: 12 Sep 2009 Points: 20488 |
The lifting capacity in those days was never rated to my knowledge. I guarantee a healthy hydraulic system can lift enough weight on the 3-point to lift the front wheels off the ground and probably even with 500 lbs of suitcase weights installed. These tractors have been used for decades hauling large round balers on the 3-point hitch, but I'd always assume there were front weights involved.
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 31064 |
Have a 3008 Bush Hog 3Pt Mounted on my 180D, HAD to ADD a Loader for ballast to keep front end on the ground as the 3Pt will lift whatever is put on it. The BH weighs 1850lbs.
Edited by DMiller - 24 Oct 2024 at 6:33pm |
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3453 |
This Escort weighed more than 2000 pounds
John426
Silver Level Joined: 14 Aug 2012 Location: France Points: 291 |
The lifting capacity of 160 is 2000 Kg ( 4400 lbs) .
For the 200 it is 2090Kg ( 4600 lbs) I have no data for the 185 Edited by John426 - 25 Oct 2024 at 2:52am |
Gary Burnett
Orange Level Access Joined: 11 Sep 2009 Location: Virginia Points: 2939 |
It'll lift more than than the front end can keep down unless it has a loader
Wes(Va)
Update: it lifts the tedder with ease! I can feel the frontend is light. Haven't gotten it in the field yet. Have weights that came off the rear axle on F2, just need a weight bracket to put them on this tractor, and it should help a bunch.
Wes(Va)
Here it is! I've never really been able to post pictures, but I think I've got it now..
