Cable Clamps and such |
nanuk
Silver Level Joined: 22 Aug 2013 Location: Saskatchewan Points: 257 |
Posted: 03 Aug 2024 at 9:55am |
As I have been having issues with my Range/Park cables, I finally was able to dig deep into them
I had previously remove the bolts holding down the bracket behind the hydraulic stack, lift up the whole area a bit, and tighten the allen head screws Dr. Allis tight be danged if everying worked... until it didn't. so I took a deeper dive into it. What I found was the C-clamp (bit of mickey mouse POS) was broken at one of the screw holes. So, now what.... I'm in Canada, the cost to buy/ship that little piece of metal would be silly... So, I thought, why didn't they use a solid rod C-Clamp/U-bolt like at the lever end of the cable. So, I made one. I went to a local hardware store, and although they didn't have any U-bolts in the size I needed, I DID find a wire cable clamp, where the U-bolt appeared to be nearly the right size. So, I bought one, took it apart, and modified the size by forming it over an anvil of appropriate size. I had to spread it out a bit, then insert the anvil into the C, and bring it back around so it was "JUST" slip over the groove. This left the legs a bit wider, so I drilled out the holes (just drilled near/between the screw holes so they remain undamaged) just enough to get it to fit through. a couple washers/lockwashers, and installed everything. (sure would be easier to have a kid there to move the lever when needed) I could access the nuts from inside the cab, through the floor. removing the bolt/bracket from on top the Range/Park shaft, and unbolting the ball/Socket cable end allowed enough movement to get at the nuts to tighten. with the really snug fit on the cable groove, I didn't get too heavy handed on the nuts, only really snug with lock washers, so I wouldn't crush the cable. I felt that the fit is better, SOLID, so there would be minimal issues with movement/slipping. bolted down the rear bracket. tried the lever and all felt well enough. Fired up and ran a test. a bit stiff as before, I assume from lack of a functioning Transmission brake, and many years of lack of lube, but worked as before. the cable alignment is just a bit lower, which keeps the cable more straight on that the original. IF I could have sourced an AC U-bolt that matched the front, I'd have gone that route, as I think the ends are identical, and it would have made life a LOT easier. I'm just putting this out there, in case anyone else is having big issues with their Range/Park cable rear clamp. I'll add, that after a few times digging into that area, the solid mechanical lever through the floor looks like a pretty easy modification. I may look into that in the future, but for now, I have my extra 10 gears at hand. |
AC7060Pd 1975
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22473 |
Well I'm impressed ! You bought ONE 'clamp' and made it work !!!! I'm a 'Noah' kind of guy, tend to order things in 2s (or 3s or 4s...... ) Maybe look at what Princess Auto has,if there's one nearby. Heck latest flyer shows that now carry front tires for D-14 ! ?? |
nanuk
Hahahaaa
PA was where I got my cable clamp But I noticed on the parts diagram the clamps are opposite of mine I have the presses metal one on the back, and a C bolt on the front |
AC7060Pd 1975
well I'd be really,really impressed if you ONLY bought that one clamp from PA !!! When I go there to pickup my order, I always have to walk the isles and 'somehow' decided I need this, that and oh yeah 3 of those......
BillinAlberta
Silver Level Joined: 12 Sep 2009 Location: Saskatchewan Points: 342 |
Yeah Jay I have the same problem at Princess Auto in Saskatoon.
nanuk
Oh, don't get me started on the bigger PA stores... about double the selection of mine in P.A.
But we do what we can, Right? I was ready to buy a long bolt, cut off the head, thread the shank, and bend it on an anvil. if I had a few days, that would have been the better option, so it fit better. But what I did worked OK, all I need to do is fabricate a heavier backing plate to replace the washers. the heavy washers I had were too wide diameter, so had to use smaller/lighter ones, and my holes had to be enlarged to fit the angled legs. |
AC7060Pd 1975
