WD45 wet clutch |
sling-it ![]() Bronze Level ![]() Joined: 01 Oct 2010 Location: Iowa Points: 32 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jul 2024 at 8:57pm |
Wet clutch stopped working after sitting a bit, so I thought it was stuck. Tear it down, and this is what I find. Any way to fix this without tearing it out? Grade 8 bolt/nut and peen the threads? I re-engaged the clutch, and it's lined back up now.
![]() Edited by sling-it - 29 Jul 2024 at 8:58pm |
btw, I know it's dry...I drained it a while back and haven't ran it since. Finally getting around to fixing it.
55allis ![]() Orange Level ![]() ![]() Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1097 |
How many are missing?
I broke one on my 45d and ended up replacing it with a grade 5 bolt shank, local blacksmith put it in his lath and made look completely original. Agco does have them as of a year ago but they was like $75-$80 bucks per pin. ![]() Hope this helps…. |
As far as I can see, only the one is missing.
How did you end up locking it in? I can see a nut working, but riveting doesn't look possible due to space.
I used the original style snap ring
Agco part 70223395 I was thinking there was a longer and a shorter pin but agco parts book shows the same number which is 70223159 Any blacksmith should be able to lath a snap ring grove in grade 5 material and that’s why I decided to use grade 5, they are originally grade 8 and maybe harder but I haven’t had a problem yet with mine… |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22087 |
You'd better finding the missing pin before it rolls thru all the PTO gears and destroys them.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8662 |
If you're lucky the pin has made it to the bottom of the PTO box. If you're wise you'll not engage the PTO before pulling it off.
I was thinking along the same lines, so today I went magnet fishing. Found something I've never seen before. The clip didn't break, it wore OUT and was still on the pin! I think agco wants about 40 or 50 bucks for that clip....NOT WORTH IT LOL
