HD5G final drive leak
51HD5G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51HD5G Quote  Post ReplyReply Direct Link To This Post Topic: HD5G final drive leak
    Posted: 26 Jun 2024 at 11:21pm
Changed final drive oils with 50 weight and on clutch side the oil leaked out rather severely.  Contemplating packing grease in, but you guys way smarter than me.  Any suggestions?  Many thanks!
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 6:55am
No greace in cluch and final drive
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 12:29pm
Originally posted by 51HD5G 51HD5G wrote:
... on clutch side the oil leaked out rather severely...
Hmmm... are you referring to the left side of the machine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51HD5G Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 12:51pm
Left side from sitting in seat.  Seems to the inside seal or whatever as it's mainly dripping on the inside portion of track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 12:55pm
Upper shafts into clutch housings are LIP Seals . Oil level on outboard side should never be high enough to pour out , on inner side the level is set by level in transmission level.
 Outboard seal of final drive is axle seal which is a mechanical seal on sprocket .
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51HD5G Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 1:12pm
What about filling final drive to level of cap on rear of tractor?  I replaced transmission oil to level of plug on side of transmission.  Does transmission oil comingle with final drive oit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2024 at 1:21pm
NO - final is set by the level in the plugs in the drawbar  , bull gear movement distributes the oil to gears and bearings within that case . Transmission oil is separate  and lubes ring and pinion and gears in transmission case only.
 Lower case uses a different oil also .
