All Crop 60A
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Topic: All Crop 60A
    Posted: 12 Jun 2024 at 11:27pm
Well I got one on an auction today and took my 45D to pull it to its new home.
It has a new reel and a new pick up chain/belt but the engine is stuck (it won’t crank over) and it has really old gas in the gas tank.
Any advice would be appreciated!!!
I’d like to get everything working to “play” with it if it’s possible…
So here comes another project!!!
Edited: I changed the title to 60A
Edited by 55allis - 16 Jun 2024 at 3:45pm
1955 AC WD45 diesel with D262 repower, 1949 AC WD, 1963 A-C D17 series 3
Post Options Post Options   Thanks (1) Thanks(1)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2024 at 11:30pm
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 6:18am
That's an interesting combine. It has a pickup head with a reel.
I see it has duals on it too. That's a nice addition.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 6:29am
I have the PTO shaft and shield if you decide to remove the engine.
http://lonsallischalmers.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 9:26am
Is the pto shaft the same as a roto baler?
I have 4 parts roto balers with the ptos…
It also has a sickle bar under it..
I’m slightly confused about what kind of head it is, it has a tag but I didn’t get a picture.
Got it from the Royal Bierbaum auction yesterday so there might be more pictures on there.
https://www.equipmentfacts.com/listings/farm-equipment/auction-results/232812773/1951-allis-chalmers-60
Edited by 55allis - 13 Jun 2024 at 9:27am
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 3:34pm
If not a perfect swap, its mighty close!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 4:08pm
Well than it would a cheep swap if I can’t convince the engine to come loose!
I sure would like to get it running if it’s possible though.
Darwin W. Kurtz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 4:42pm
nice machine, unusual set up, hardly ever see one with the engine.....wouldn't that be the same engine as some of the popular tractors of that time, seems some of those have been swapped in the past
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 5:05pm
Same engine as a ‘B’ or possible ‘C’?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 6:27pm
Do you have the manual for that unit?  And what is the serial number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 6:58pm
I only have a online parts catalog.
I don’t even know where the serial number is on the machine…
I know it’s missing at least a 4 belts so I’m going to need to cross them.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 8:09pm
I have an original AC manual that covers operating instructions, special attachments, and repair parts book.  Says it covers serial 93799 and up.  I've had it for years and I'm never going to use it so if you send me a private message through the Forum with your mailing address, I'd be happy to send it to you.
It's in good shape and complete for it's age.
Don Jr NY View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Don Jr NY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2024 at 5:05am
The serial number is stamped into the left hand side of the machine right under the threshing cylinder shaft. Left/Right is always as you are standing behind the machine looking forward. Hope this helps.  Don Jr.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2024 at 11:06am
The serial number is I think A54731.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2024 at 2:02pm
This one is for 93799 and up, but it would probably have all the info you would need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darwin W. Kurtz Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2024 at 3:31pm
That would be a 60 A series machine, since serial number starts with A, I guess the A's were somewhat updated, don't reall know the difference in the actual machines, but they are different and I don't think there were nearly many 60A's built
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2024 at 3:40pm
Here’s what I found online…
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2024 at 4:51pm
Well the engine is shot…
I pulled the head and found 1 broken sleeve and 4 out of 4 broke up pistons…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2024 at 5:10pm
Nah, couple cans of WD40, charge up the battery, and your good to go!!
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jun 2024 at 9:48pm
At least it's not some oddball manufacturer's engine. You should still be able to get all the parts you need since it's the B/C engine in power unit form.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 9:48am
New sleeve and piston set and a couple of gaskets and you're well on your way!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 3:44pm
Well I think I’m going to put the pto on it for now and than eventually get the engine to run (overhaul and clean it up).
Does anyone know of a stock of parts for the 60A?
It needs 3 pulleys, elevator door (rusted out), and a elevator chain.
That’s what I seen so there’s probably more things that I haven’t notice….
dr p View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dr p Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 7:56pm
Tom yaz will have it all
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2024 at 10:39pm
Which pulleys do you need. We also have a bunch of pulleys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 5:33am
I have some parts for sale.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2024 at 11:27pm
Well I have good news today, I was cleaning the walkers out and found the 2 pulleys and the rest of a slip clutch all in the coon crap so praise the Lord!!!
Now the one slip clutch with 3 spring is missing 2 out of 3 springs and the single spring one is missing it’s spring.
So now I need to repair and replace parts of the elevator chains (salvage what I can) and figure out belt sizes.
Also I think the draper needs to be tightened because it won’t turn unless I hold it tight.
I also tried to get the engine clutch to move but knew instantly that it’s going to have to be replaced because the springs are falling out so I’m really hoping that it’s the same clutch as the tractor B…
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2024 at 5:39am
I"m interested in the header. That's an interesting setup. Good luck getting it running
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2024 at 9:35am
I found another one down in a neighbors creek that possibly could have some parts salvageable… It’s upside down and beat up pretty bad I’d say….
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2024 at 11:43am
Restore it man!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2024 at 3:15pm
Restore it man!!
I think it’s a tad gone to far…
This page was generated in 0.045 seconds.
