I600 hydraulic problems |
Thad in AR.
Joined: 12 Sep 2009 Location: Arkansas Points: 9731 |
Topic: I600 hydraulic problemsPosted: 02 Jun 2024 at 8:27pm |
First, one of the outrigger cylinders is leaking. It has the end cap welded on and the weld is leaking.
How should I go about fixing this? Second, the Cessna rotary swing cylinder started leaking top and bottom. Where can I get parts? |
desertjoe
Joined: 23 Sep 2013 Location: New mexico Points: 13769 |
Posted: 03 Jun 2024 at 8:32am |
Hey Thad,,, I went thru similar repairs on the rotary swing cylinder and one of the backhoe's cylinders on my tractor some years ago,,,I went back to try to find my write up but couldn't find it,,,,WTH,,,,??? There was a gentleman on here that I bought the new seals from for a complete overhaul of that rotary cylinder and his name and address were in my thread,,,(hope he's still around) |
Thad in AR.
Posted: 03 Jun 2024 at 11:43am |
Yes hoping |
Thad in AR.
Posted: 03 Jun 2024 at 3:52pm |
I once saw a write up on converting one of these to cylinders. Anybody know anything about that?
Edited by Thad in AR. - 03 Jun 2024 at 6:34pm |
Thad in AR.
Posted: 04 Jun 2024 at 12:51pm |
I found an Agco parts number 837180M92
$736.00 Is there a way to see if this is correct? |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42269 |
Posted: 10 Jun 2024 at 12:27am |
The end cap on cylinder seems to be a common problem and clean and weld it up is the solution . On my hoe off my HD4 both cylinder end caps cracked next to barrel of cylinder , I just v ground the joint and welded it up without disassembling cylinder by moving piston to full extend .
Left some posts on your other post on the Cessna motor |
Thad in AR.
Posted: 10 Jun 2024 at 5:22am |
So I don’t have to disassemble the cylinder? I’ll give this a try. Thank you Coke. |
Coke-in-MN
Posted: 10 Jun 2024 at 11:37am |
With cylinder off machine and ports open so any content left in cylinder can gas off , just clean up area and V out part of old weld and carefully lay a bead over area for repair .
Thad in AR.
Posted: 13 Jun 2024 at 5:19am |
Thank you Coke. I’ve been using it hard lately . Things are starting to show their age. I have some work to do for sure. |
