Jacobsen mower? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Topic: Jacobsen mower?Posted: 30 May 2024 at 10:47pm |
What makes a zero turn mower want to whine-chatter sound when first moving full pedal either direction? Could it have air in the hydros? How do you get it out? Thanks, Tracy
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55301 |
Posted: 31 May 2024 at 4:18am |
Indicates cavitation at the hydro pump, check oil level, filter, hoses...
Codger
Posted: 31 May 2024 at 6:59am |
What model and serial number Jacobson? Ransomes/Jacobson use many hydrostatic drive vendors.
That's All Folks!
Tracy Martin TN
Posted: 31 May 2024 at 3:45pm |
It is a Jacobsen 445g Turfcat. I think mid 90's about 1000 hrs. Has separate pump for hydro and engine driven off crank for blades. Thanks, Tracy
Codger
Posted: 31 May 2024 at 3:59pm |
Either "Tough Torque", or a "Hydreco" hydrostatic drive pump from the sounds of it.
That's All Folks!
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8406 |
Posted: 31 May 2024 at 5:02pm |
Does the chattering go away after a short time?
Codger
Posted: 31 May 2024 at 8:09pm |
Need serial number to drill down for correct machine. 2WD, or 4WD? Ford gasoline engine?
That's All Folks!
Tracy Martin TN
Posted: 31 May 2024 at 10:14pm |
2wd with Ford engine.Thanks, Tracy
