8050 Injector Stuck in Head |
   977.3Ford
   Joined: 04 Oct 2019 Location: Dayton, Ohio Points: 103  |
      Quote   Reply
     Topic: 8050 Injector Stuck in HeadPosted: 26 Feb 2024 at 10:04am  |
   I've pulled the injection pump off my 8050 to have it rebuilt due to some leaks and figured i'd send the injectors out as well while its apart. #2-6 all came pretty easy but #1 is stuck tight. I tried spinning it loose with a wrench but it started to unthread the body of the injector from the nozzle. I'm thinking about making a puller to fit under the turbo, or if it comes to it pulling the turbo/manifold and using a slide hammer to try to pop it out. Is there much of a risk of breaking the injector off in the head? I'd rather leave this injector alone than open a whole can of worms I don't want to deal with.
  Edited by 977.3Ford - 26 Feb 2024 at 11:05am  |
     Jimmy
  1982 8050 Powershift 1982 6080 1992 R52 Gleaner  |
      Quote   Reply
     Posted: 26 Feb 2024 at 10:38am |
   If you've turned the injector body you are in deep-doo-doo. Probably have to remove the cylinder head to drive out the nozzle tip and nut with a hammer and punch. The nozzle tip threads onto the nozzle body and you've potentially broke things loose. Slide hammer on the injector tip yes. Remove manifold probably.
   977.3Ford
      Quote   Reply
     Posted: 26 Feb 2024 at 12:02pm |
   Yes unfortunately it broke loose and the body got turned less than 1/8th of a turn when I realized what was happening.
     Jimmy
   977.3Ford
      Quote   Reply
     Posted: 26 Feb 2024 at 2:58pm |
   Crisis averted. Made a crude puller and with some tapping from a hammer I was able to walk the injector out after a while.
     Jimmy
   tbran
   Joined: 14 Sep 2009 Location: Paris Tn Points: 3539  |
      Quote   Reply
     Posted: 26 Feb 2024 at 4:17pm |
   We used a pneumatic air chisel after soaking a day - while pulling on the nut threaded to the top.   The vibration helps big time.  The same method we use getting the head bolts to break loose on a Deutz. Hammer and pull/twist. A bosch puller can be made with a deep well socket or tube... you can buy them - or could years ago.
     When told "it's not the money,it's the principle",  remember, it's always the money..
   bigal121892
   Joined: 05 Jan 2010 Location: Nebraska Points: 815  |
      Quote   Reply
     Posted: 26 Feb 2024 at 5:14pm |
   I have gotten them out, by just barely loosening the hold down bolts, then crank the engine.
| Forum Jump | Forum Permissions  ![]() You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum  |
