175 GAS STARTING ISSUE |
SIMPLICITY
Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 511 |
Topic: 175 GAS STARTING ISSUEPosted: 20 Feb 2024 at 7:18pm |
HELLO I'VE GOT A 175 GAS REPLACED THE CARB. HAD NO LUCK REBUILDING ORIGONAL ,CONVERTED TO ELECTRONIC IGNITION , FOR THE LIFE OF ME I CAN'T GET THIS TRACTOR STARTED. I'VE GOT A BUDDY THAT PICKED ONE UP THAT HAD BEEN SITTING UP FOR 6 OR 7 YEARS AND HAS POINTS , PUT GAS AND A HOT BATTERY AND SHE STARTED RIGHT UP. AS LONG AS WE'VE BEEN HAVING THAT TRACTOR SHE HAS ALWAYS BEEN A MOTHER TO START , TURN ,TURN,TURN, A LITTLE CHOKE THEN SHE WANTS TO FLOOD OUT AND IF SHE'D START YOU'D HAVE TO HOPE SHE'D STAY RUNNING TILL SHE'D WARM UP, AT THIS POINT I SWARE I'D SELL IT FOR SCRAP. ANY HELP WOULD BE APPRECAITED
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54465 |
Posted: 20 Feb 2024 at 7:40pm |
Have you made any checks on compression or ignition? Sometimes its more than 1 problem...
Joined: 11 Sep 2009 Location: illinois Points: 88649 |
Posted: 20 Feb 2024 at 8:52pm |
If you have spark and gas.......... i would check the TIMING... Several degress off will make them HARD to start. ...... could be the point slipped or burnt contact and that changed the timing.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3952 |
Posted: 20 Feb 2024 at 10:17pm |
also check valve lash
soggybottomboy
Silver Level Access
Posted: 21 Feb 2024 at 2:06am |
Check the voltage while the starter is turning. Electronic ignition needs 12 volts to fire. If your voltage drops while the starter is turning it will not start.
Posted: 21 Feb 2024 at 6:26am |
"Borrow" a known good-starting carburetor from a WD45 or D-17 and try it on this hard starting engine. Still doesn't start good, it ain't the carb.
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 23 Feb 2024 at 4:01pm |
How old are the spark plug wires and what brand spark plug are you using?
